Speedometer not working? - Kawasaki ZX-10R.net
 3Likes
post #1 of 12 Old 08-16-2017, 05:18 PM Thread Starter
07_ZX10R's Avatar
Question Speedometer not working?
So when I got the bike the speedometer wasn't working. All the guage and instruments were good but it just read 0 mph at every speed. The day after the F1 code came up with the trouble light. Trouble code was 24 which is speed sensor. I haven't looked into it too hard but I just wanted to know what the likely culprit would be. Bad speed sensor at the sproket, cable pinched or cut, or maybe someone grinded off the tab to override the 189mph speed limiter? Should I follow the service manual procedure for checking the speed sensor, then trace the cable all the way up to the instrument panel? Where does the cable run through? Any help is greatly appreciated.
07_ZX10R is offline
post #2 of 12 Old 08-16-2017, 05:59 PM
SkyDork's Avatar
So many typos though. "Grinded off" isn't even a phrase. Let alone grinding off a tab to overcome the speed limiter since that won't work.
First, it's an "FI" light. As in, Fuel Injection, Fault Indicator, etc. It's NOT an F1 light. As stated here....
All Gens: So, your "FI" light is on.....
Secondly, it's likely the sensor is just bad. That's the common failure point on them. It's connected directly the harness, so if there's an issue with wiring, that's not likely and would require and new main harness for the whole bike.
Third, it could also be the instrument cluster, but that's rare. You'd have to pull the cluster, put power on it to fire it up on the bench, and then provide an input voltage on the speed sensor pins to verify that the cluster reads something. But the sensor itself is more common than this.
Capncalyx and thundercoupe9 like this.
#WordCrimes
SkyDork is online now
post #3 of 12 Old 08-16-2017, 06:13 PM Thread Starter
07_ZX10R's Avatar
Great, thanks SkyDork. My bad, I just got the bike and was going off of stuff I read in the forums and the manual. Damn, thought it read F1, FI does make more sense. Lol. So how is the speed limited on the Gen 2s? I thought the ECU went off the speed sensor to know when to limit it.
07_ZX10R is offline
post #4 of 12 Old 08-16-2017, 10:22 PM
thundercoupe9's Avatar
Those darn F1 lights Go Scuderia Ferrari.
thundercoupe9 is offline
post #5 of 12 Old 08-17-2017, 09:38 AM
SkyDork's Avatar
Helitech likes this.
#WordCrimes
post #6 of 12 Old 08-17-2017, 09:47 AM
SkyDork's Avatar
It basically does limit the speed using the sensor and a couple other inputs, from what I recall. It's been 11 years since I had mine and was up to date on all the mods for it.
But, the speed sensor gets it's input from the output shaft of the transmission. So I'm not sure what "tab" the previous owner would grind off. If he cut a wire, that just makes the ECU think the bike isn't moving and may not defeat any limiter. Some people back then used to use a speedohealer to try and slow the displayed speed down some. But tons of people have had an erratic/failed sensor that does as you describe, so I wouldn't really worry about some sort of defeat setup until the sensor and cluster are checked out.
#WordCrimes
post #7 of 12 Old 08-17-2017, 10:01 AM
I hope Mercedes grinds their teeth to remove speed limiter and doesn't follow service manuals and take advice from fb mechanics, Ferrari will have championship in the bag
post #8 of 12 Old 08-17-2017, 10:16 AM
SkyDork's Avatar
Stranger things have happened! I'm sure someone at Mercedes has tried that. Go Ferrar1!
#WordCrimes
post #9 of 12 Old 08-17-2017, 10:19 AM
I don't know about Merc, i am sure Honduh build their power units taking advice from fb mechanics
post #10 of 12 Old 08-17-2017, 10:27 AM
Check the output voltage on the speed sensor.
Name:	8-17-2017 10-25-32 AM.jpg
camaroguy72 is offline
