Gen 4: 2011-2015 Seems like I'm already flashed...Can ECU still be tuned? - Kawasaki ZX-10R.net
 2Likes
post #1 of 17 Old 02-21-2017, 01:35 AM Thread Starter
Question Seems like I'm already flashed...Can ECU still be tuned?
Hey all,
Just got a gen 4, and I was unsure if it had been flashed as it's got a decat and end can plus other mods.
Someone mentioned that I should try changing TC settings on the move, and lo and behold I can, so I guess I'm flashed.
Trouble is, the bike is running rich and I had already booked the bike in to have ECU flashed, and the fuelling tuned.
So I wanted to ask, does the ECU need to be reflashed depending on which software was used to flash it, in order to adjust fuelling (I don't want any piggyback modules)?
Is there any way to check which software was used?
Also, I want to fit the Translogic quickshifter off my GSXR 1000, which I have been told is possible (just need a wire swap).
Anyone know what I need to do?
I would obviously like to avoid paying for the fixed price flash if I can.
Cheers
10Arghh is offline
post #2 of 17 Old 02-21-2017, 03:38 AM
Helitech's Avatar
You can change TC settings on the go on a non flashed ECU. Most flashes allow you to turn it OFF while on the move. Try that and report back.
mpp12 and Zed-xer like this.
Helitech is online now
post #3 of 17 Old 02-22-2017, 03:07 AM Thread Starter
Thanks.
Yep can only change TC on a closed throttle and lowest it goes down to is 1.
Does the display actually show [b]off[\b] when TC is off, or does that section of the display just show as blank?
Thanks.
10Arghh is offline
post #4 of 17 Old 02-22-2017, 03:23 AM
Helitech's Avatar
It'll show as "OFF" just above the numbers slightly off center to the right.
This doesn't mean your ECU Is not flashed. Maybe that option just wasn't done. If you look at your ECU, most reputable companies put their sticker on the ECU itself.
post #5 of 17 Old 02-22-2017, 09:37 AM
belkins's Avatar
Originally Posted by 10Arghh View Post
Thanks.
Thanks.
usually on a flashed bike also it will retain your traction control setting and power mode you have set instead of resetting to default settings on every start of the bike. and as helitech said they usually put a sticker on the ecu itself letting you know who flashed it.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #6 of 17 Old 02-22-2017, 10:13 AM Thread Starter
Thanks guys...Ok..More investigation required
Just hard taking eyes off the road to look at dash
Only a different note (and probably not a good idea), but has anyone run the bike in gear on a stand?
Does that make the TC go crazy due to the big difference in wheel speed?
10Arghh is offline
post #7 of 17 Old 02-22-2017, 12:10 PM
Porschenut's Avatar
Chances are that you aren't flashed then. I can't imagine why anybody would go to the effort of flashing without removing the traction control restrictions when they suck so badly. Removing the TC restrictions is one of the primary selling features of a flash.
You can run the bike on a stand on idle (I've never dared applying throttle). I know it's a bad idea but I've done it a million times to save time while spray waxing my chain. When I think about it, I'm pretty sure I've done it many times even while in TC setting 3 so either the wheel speed is staying below the threshold for activation (check the manual - I think it's 25kph?) or the bike knows that it's on a stand somehow.
Porschenut is offline
post #8 of 17 Old 02-22-2017, 04:49 PM Thread Starter
Porschenut that's how I do my chain as well, just mind your fingers as have known a few guys lose them through spinning chain interface.
Ok si the mystery (minor) continues...I can change and turn off TC whilst the bike is rolling, but not when the throttle is being applied.
I guess I should dig out the ECU.
Where is it on this bike?
Cheers.
10Arghh is offline
post #9 of 17 Old 02-22-2017, 05:17 PM
Porschenut's Avatar
There's no mystery. If you can turn the TC to OFF while rolling (and I mean OFF, not setting 1, 2 or 3) then your ECU is flashed.
post #10 of 17 Old 02-22-2017, 06:18 PM Thread Starter
Great, yes it said Off on the dash after I held the TC button down long enough.
Guess my other question is, don't ECU software vendors lock an ECU to the specific computer and software it was flashed from?
I'm worried how my tuner will map the fuel table with his Woolich software.
Also is quick shifter functionality enabled through the ECU?
10Arghh is offline
Tags
ecu, flash
