Gen 4: 2011-2015 Replacing gen 4 rear shock with gen 5 showa bfrc - Kawasaki ZX-10R.net
 11Likes
post #1 of 66 Old 03-09-2016, 08:47 AM Thread Starter
Question Replacing gen 4 rear shock with gen 5 showa bfrc
dear members,
I would like to ask whether is it possible to install gen 5 showa bfrc rear shock to the gen 4?
It seems like a direct fit, except from the pictures the rear linkage seems a bit different.
I am not sure about the dimension for gen 4 and gen 5 if they are different or same.
Hopefully someone can help me here..
Thank you a lot for reading and giving advice.
reemba19 is offline
post #2 of 66 Old 03-09-2016, 09:04 AM
SkyDork's Avatar
Hi.
I'd bet money on it fitting. But the linkages are different which will throw off the action of the shock. The swingarm on the G5 is also longer. So bolting on a G5 shock may not provide much if any benefit without matching the ratios with the linkages and longer arm.
White Fang likes this.
#WordCrimes
SkyDork is offline
post #3 of 66 Old 03-09-2016, 09:13 AM Thread Starter
Hi SkyDork,
Thank you very much for you reply.
The reason why i plan to fit G5 rear shock is because my current G4 rear shock is now in need for replacement.
i don't have the budget to buy Ohlins, so i'm looking for better alternatives.
Besides, i only go for track day 2-3 times a year, and only to practice my cornering skills.
Do you think it's worth to choose G5 rear shock?
Thanks again..
reemba19 is offline
post #4 of 66 Old 03-09-2016, 11:19 AM
SkyDork's Avatar
Originally Posted by reemba19 View Post
Hi SkyDork,
Thanks again..
It would be the cheapest to have your existing shock serviced. You can opt for a new spring as well. That would be cheaper than finding a used G5 shock and way cheaper than aftermarket. If budget is your concern, I'd stick to a rebuilt G4 shock with upgrades over trying to find and fit a G5 shock.
#WordCrimes
SkyDork is offline
post #5 of 66 Old 03-09-2016, 03:53 PM
Always On Mod
Animal11's Avatar
The revalved rebuilt G4 shock with the correct shims for ride height is a lot better than stock and will definitely give you some improvements in the way the rear behaves on corner exit.
fitting the g5 shock to a g4 will fit, but it gives an unknown quantity in terms of performance
SkyDork and Turbodc2 like this.
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #6 of 66 Old 03-10-2016, 03:27 AM
Try it and report back
it will fit up, the bike is 15mm longer than the gen 4, I'll admit im guessing but if you look at the images between the gen 4 and gen 5 swingarm the majority if not all the extra length is at the chain adjuster. Obviously the new link on the Gen 5 is more like the race links from Gen 4 so more linear.
If anything using the gen 5 shock on gen 4 you shouldn't need to shim the bike as much IF it is in fact a longer shock.
RBZ10R is offline
post #7 of 66 Old 03-11-2016, 02:28 PM
trackdaypro's Avatar
I would try it, the gen4 shock is one of the worst Ive ever had on a bike. I bought two brand new gen4 shocks off ebay and tried everything to make them work. Problem is the cost of getting them fixed to a point that they work you would be better off spending on a used ohlins. The gen5 shock might work right away or only need a new spring, its worth a try. fyi I ended up with an ohlins and aftermarket linkage in the end, now the bike is on rails. Good Luck
trackdaypro is offline
post #8 of 66 Old 04-02-2016, 01:19 AM
that's good
lawkmlaw is offline
post #9 of 66 Old 04-02-2016, 09:38 AM
mpp12's Avatar
If you are using a gen5 shock, you will have to change the links.
The gen5 has a longer 2 links more chain. So its longer but if you change the chain you will have same effect.
To me that is a lot of work and money.
I have a rebuilt Gen4 shock (stock spring), can send it to you, with dyno of the shock and everything. Only used it for 4 months. I was night and day from stock. 200usd TYD
mpp12 is offline
post #10 of 66 Old 05-26-2016, 01:20 PM
Gen 4 shock is absolute rubbish.
Im gonna fit gen5.
Any info to help would be great thanks
ukzx10r is offline
