Gen 3: 2008-2010 Removing small amount of fork oil - Kawasaki ZX-10R.net
 12Likes
post #1 of 25 Old 05-13-2017, 08:56 AM Thread Starter
Is it possible to remove a small amount of fork oil with the forks in place? My rebound is too slow even with it all dialed out. I believe if I take a little oil out that it will help a little which is really all I need
I don't want to go through the hassle of stripping the forks down and doing an oil change which is probably what I should do.
Is there a handy way of doing it by popping the caps and any idea how much I should take out?
Tearaway is offline
post #2 of 25 Old 05-13-2017, 09:08 AM
skidooboy's Avatar
if your rebound is too slow, the amount of change you are trying to get, is not enough to get, by removing oil. the forks need servicing, and more rebound shims added in the shim stack. read: re-valve. you want your adjusters to have room to move, on either side, so you can make adjustments. having them maxed out, then trying a Band-Aid, is not a solution to the problem.
it doesn't take that much to remove the forks for service. just bite the bullet and do it right so, you don't cause more or different issues, later. Ski
SkyDork and kapp241 like this.
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #3 of 25 Old 05-13-2017, 09:25 AM Thread Starter
Thanks Ski,
I know you're right... but I don't have the time nor finances to stick into this bike at the moment ( if my misses sees me heading for the garage one more time it'll be divorce )so I want to try a quick fix first and then if that doesn't work I'll bite the bullet. The improvement I'm looking for is minor!
Tearaway is offline
post #4 of 25 Old 05-13-2017, 09:40 AM
I dont see how you will accomplish a rebound change with oil level. Heres a good article talking about oil height, and what it does.
Keep in mind, hes talking dirt bike forks with 12 inches of travel..but the idea is the same.
Motocross Action Magazine HOW TO FIX YOUR FORKS WITH FORK OIL HEIGHT TRICKS | Motocross Action Magazine
rcannon is offline
post #5 of 25 Old 05-13-2017, 09:55 AM Thread Starter
You could very well be right. According to the article it will just let the oil move more.
Would an oil change to a lighter oil do the job? I'm only after a small improvement!
Tearaway is offline
post #6 of 25 Old 05-13-2017, 10:13 AM
chiffeee's Avatar
the way to do it on the bike is, to open the cap on top and using a measuring tool and a tool that looks like a syringe to add/deduct oil.
but these guys are right .by taking oil away not going to make any difference and could make the forks not functioning correctly . adding oil makes the difference from stock level. making the compression and rebound slower . but if you go lower then standard level for that fork (usually 122mm) then can make the fork create air bobble and not functioning correct.
By changing the oil weight can make what you need to achieve, but keep in mind the stock oil usually is low on its weight and you may not find lower weight , usually what i have seen people go to a higher weight and lower air gap to make the forks stiffer/ slower on rebound and compression.
only way to do it correctly is to re valve the forks.
chiffeee is offline
post #7 of 25 Old 05-13-2017, 02:02 PM
Bottoms-Up's Avatar
This sounds like a bigger issue then slow rebound.
skidooboy and mpp12 like this.
Bottoms-Up is offline
post #8 of 25 Old 05-13-2017, 03:47 PM
skidooboy's Avatar
thicker oil would help, less oil will hurt. you need to get the mrs interested in riding herself, then you dont have "those issues"... but, then everything you do with bikes, toys costs double. don't ask me how I know. :D Ski
post #9 of 25 Old 05-13-2017, 04:21 PM
If you have rebound that is "too slow", a lighter oil is what you are looking for.
A thicker oil will have a more difficult time traveling through the valving, and slow rebound.
Im not sure what specific fork oil we are supposed to have. If its showa ss7, and it may be, that looks like its a 5w.
This chart works really well as it lists so many of the fluids we have access to. You can see, also , that someones 5w may be different than others 5w. They break the fluids down and measure in cSt centiStokes. Suspension Fluid - Pvdwiki
Just a fancy name for soemthing more accurate than 5w, 10w, etc. The lower the number, the thinner the fluid is.
From the list, the redline (like water, clear) fluid is probably the easiest to get. My local shop sells it.
Lets say you dumped out the stock oil, then switched to this redline, it should lighten the rebound. I say SHOULD because as chiffeee said, the stock oil is like water, anyway.
The bad part about messing with oil weight is it also messes with compression damping. It will make that lighter, as well.
As a compromise, I think I might try this.
Wanting to decrease rebound makes me think the fork is harsh. Hits a bump and does not ready itsle , fast enough, for the next bump.The stock Kawasaki forks get pretty harsh, halfway through their travel.
How about increasing preload, a few turns. Bring the fork back up to a position where its not running into the middle of its travel so easily.
At that point, the bike may be too tall. Bring the fork up through the top triple clamp 5mm so the front end stays about where it was.
The cartridge forks are a pita to deal with, in regards to oil. Unless you get 100% of the oil oil out, you'll end up with some odd mixture of stock and aftermarket fluid. Even if it were amazing, you would never be able to duplicate it again if you blew a seal, or needed fork service.
rcannon is offline
post #10 of 25 Old 05-13-2017, 10:06 PM
skidooboy's Avatar
my bad, I read the original post wrong, I thought he did not have enough rebound dampening, and was looking to slow the rebound down more. (the gen4 rear shock is like that, not enough rebound dampening in the shock adjustment).
thinner oil would help but, still be a band aid. Ski
rcannon likes this.
