Gen 2: 2006-2007 problem o2 sensor - Page 2 - Kawasaki ZX-10R.net
 1Likes
post #11 of 15 Old 02-14-2018, 01:35 PM Thread Starter
Originally Posted by SkyDork View Post
I have no idea what those little plugs are or what they are supposed to do.
The o2 heater is part of the sensor itself and is not separate. So if you're getting the error while using those plugs, then there's something wrong with them, there's something wrong with the wiring to them, or they just don't remove that error. What happens if you plug the o2 sensors back in? Does the error go away?
When I put in the sensors again the errors that appear are
33 - Oxygen sensor #1 inactivation, wiring open or short (Europe Models)
83- Oxygen sensor #2 inactivation, wiring open or short (Europe Models)
67 - Oxygen sensor heaters (#1 and/or #2) malfunction, wiring open or short (Europe
Models)
Bruno Brito is offline
post #12 of 15 Old 02-14-2018, 01:49 PM
SkyDork's Avatar
Models)
That's not good. If those little plug-in units cause the same error 67 as the sensors themselves, then you have a wiring issue going on. Have you checked the fuse to the o2 heater? If that's OK, then you need to trace the wiring in the harness to see if it is connected out all the way back to the ECU.
#WordCrimes
SkyDork is online now
post #13 of 15 Old 02-14-2018, 01:55 PM Thread Starter
When I plugin these little pieces of the photo I only get the error 67
When I plugin the sensors instead of these plugs it is that errors 33, 83 and 67 appear, which is the heating fuse?
post #14 of 15 Old 02-14-2018, 02:09 PM
SkyDork's Avatar
How do you know that those plugs are designed to override code 67? They may not. If you know that they should clear all the codes, then you have a wire problem or a power problem. Or they are defective.
The fuse is a 10A fuse and should be labelled in the panel under the rider seat. Check that first to be sure it's not blown.
#WordCrimes
post #15 of 15 Old 02-14-2018, 04:24 PM Thread Starter
SkyDork, first of all, thank you for your patience and willingness to help me, I came home and took everything apart and I'll tell you what I did.
1 - I tested all fuses and they ok
2 - I unplugged those plugs and turned on the sensors
3. I started the motorcycle with the engine running
4 - I virified errors, (error 67 present)
5 - I turned the sensors off and started the bike again.
(error 67 33 83 present)
6 - I turned on sensors o2 again (error 67 present)
7 - I turned off and I plugged in the photo cards Error 67 Present
