Gen 5: 2016 -> OEM Quick Shifter is Terrible! - Page 5 - Kawasaki ZX-10R.net
 7Likes
post #41 of 55 Old 05-01-2017, 11:48 AM
cosmic_ocean's Avatar
Originally Posted by chiffeee View Post
I am not sure that 100 is in ms, lower than 70 had a bit of problem shifting in my experience.
Thank you Chiffee. Well, it cannot be in 'ms' for sure. Kawasaki seems to have an Rpm based kill time and not gear based, as the timing is perfect in low as well as higher revs. The stock QS works amazingly in my Gen-5. However, I'd like to know the stock timing before I flash the ECU with Woolich, just in case I want to revert to stock. Can anyone shed some light?
cosmic_ocean is offline
post #42 of 55 Old 05-01-2017, 12:01 PM
Originally Posted by Nfamous60 View Post
my settings now are 85 first gear 90 for the rest should I continue going down or increase the number I went as far as 80 for all gears doesn't seems to have any change to it at all.
The kill times reduce as the rpm's go up and not the reverse in the regular qs, where we set the times between 52-56ms. That being said, I'm not sure what the 100 value means in the Woolich setup
post #43 of 55 Old 05-03-2017, 12:28 AM
OK, I set Gear 1 at 100, 2-94, 3-88, 4-82, 5-80 and its smooth as butter. Anyone fine tuned the autoblipper downshifts? What values if so?
post #44 of 55 Old 05-11-2017, 03:10 AM
@cosmic_ocean: Are you talking about settings in the race ECU or stock ecu flashed?
morpheusro is offline
post #45 of 55 Old 05-11-2017, 03:11 AM
Are you talking about settings in the race ecu or in the stock ecu flashed?
post #46 of 55 Old 05-14-2017, 11:55 PM
Stock ECU bro.
post #47 of 55 Old 05-27-2017, 12:37 AM
i set it 65/60/55/50/45ms for track
If you shift lower rpm. i would put it around 75/65/55/50/50ms for street.
woolich kawasaki stock is all set at 100ms. probably reason for terrible shifting.
Hieu Le is offline
post #48 of 55 Old 05-30-2017, 08:58 AM
Niner1000RR's Avatar
My issue with the EOM QS wasn't kill times, it was the amount of movement allowed by the switch itself. Drove me nuts.
Niner1000RR is offline
post #49 of 55 Old 06-02-2017, 04:05 PM
Ron Mears's Avatar
Agreed. The throw is very long.
Ron Mears is offline
post #50 of 55 Old 06-06-2017, 04:34 PM
OK, I was thinking about race ECU but should make no big difference.
