Gen 5: 2016 -> OEM Quick Shifter is Terrible! - Page 4 - Kawasaki ZX-10R.net
 7Likes
post #31 of 55 Old 04-19-2017, 02:37 PM
How did you improved the QS feel? With race ECU what kill times and judgement voltages did you set?
I'm curious as I have race ecu and I didn't manage in the first place to make it work...
morpheusro is offline
post #32 of 55 Old 04-19-2017, 02:37 PM
Actually, I think that most important question is: how did you calculate voltages for judgement voltage UP/DOWN ?
post #33 of 55 Old 04-19-2017, 05:10 PM
dricked's Avatar
Try the stock settings first. Make sure it's turned on at the dash too, mine was off by default.
dricked is offline
post #34 of 55 Old 04-20-2017, 02:23 PM
It's turned on and I have absolutely no clue what the stock settings are because I have removed the stock ECU and I have installed the race ECU...
post #35 of 55 Old 04-20-2017, 07:34 PM
dricked's Avatar
Ok well the "stock" settings in the race ecu. If it's turned on in the ecu and at the dash but still isn't working then I'm not sure what else to suggest.
dricked is offline
post #36 of 55 Old 04-20-2017, 08:40 PM
Newf's Avatar
Stock Race ECU default map has 5ms for cut time. Adjust that to around +/- 50ms for each gear and check to make sure you have the right setting 4 or 5 depending what way your shifter is setup. If you do change shift direction (4or5) you also have to change the switch the voltages.. that's how it's in on my std and modified map anyhow.
Newf is offline
post #37 of 55 Old 04-20-2017, 08:46 PM
dricked's Avatar
I wish I could help more but I was given a map with all that jazz already fixed up.
I didn't see in the manual having to change the voltages, just the 4/5 for standard/reverse shift.
dricked is offline
post #38 of 55 Old 04-21-2017, 02:32 PM
Hi guys,
In the manual it says that for road shifting the setting is 4 and for reverse is 5.
And yes Newf, you are right you have to change voltages and in order to find out which voltages to set, it's necessary to use the Monitoring tool included in the software.
I will do that over the week-end and let you know how it worked, but I think this is the way to go.
post #39 of 55 Old 05-01-2017, 10:59 AM
cosmic_ocean's Avatar
Kill times
Just a simple query. What are the stock kill times set for the QS by Kawasaki on the Gen-5? Are they 100 for all gears as shown in the stock Woolich map?
Have always set QS kills times between 52-55ms in most standalone quick shifters that I've used on track. What does this 100 value mean?
cosmic_ocean is offline
post #40 of 55 Old 05-01-2017, 11:20 AM
chiffeee's Avatar
I am not sure that 100 is in ms, lower than 70 had a bit of problem shifting in my experience.
cosmic_ocean likes this.
chiffeee is offline
