Gen 4: 2011-2015 My 2013 won't start, and I'm looking for any input. - Page 3 - Kawasaki ZX-10R.net
post #21 of 24 Old 03-20-2017, 02:39 AM Thread Starter
Dustin Wehmeyer's Avatar
I was able to get it running correctly today. However I have no real idea what exactly was wrong. I had to fix a couple issues I created trying to get it running, but I never found anything that would explain what was wrong to begin with.
https://youtu.be/RbVwy_j2RPo
Dustin Wehmeyer is offline
post #22 of 24 Old 04-28-2017, 01:40 PM Thread Starter
Ok -- what a saga this has been.
Even after getting the bike to run, I had a problem which I just couldn't figure out.
The engine would hit 12500 RPM and cut out. RPM would drop to about 11000 RPM and engine would come back on full power. Bucking like mad in the process -- see the video of it below.
Turns out that my crankshaft position sensor was faulty. Not enough to keep the bike from starting and running mind you.
I had tested and verified the sensor was working per specs for resistance and open circuit peak to peak voltage. Mine measure 490ohm (spec is 376 - 500) and 2V peak to peak output (min spec is 1.9V). Based on that and the fact the engine started and ran just fine, I didn't suspect the crank sensor was faulty and would only fail completely at high rpm and then start working again at a lower rpm.
I went back and retested the sensor after a couple of weeks, as I was completely out of other ideas to fix the issue. This time when I checked, the resistance was in spec, however the open circuit output voltage was only 1V. Once the replacement sensor was in, I verified the output voltage and it was 3V. 3x higher output voltage.
My best guess here is the crank sensor signal was not strong enough at high RPM to outweigh the electrical noise of the engine pulling 12,500+ RPM.
I also have to assume the bad crank sensor was why I was having so many odd problems from the get-go. Live & learn.
post #23 of 24 Old 04-29-2017, 02:36 AM
lenshead's Avatar
I doubt it had to do with electrical noise so much as inductance. If your magnetic CS sensor is marginal in the first place, then output could conceivably lower at higher frequencies. At 12500 rpm it would be putting out pulses in excess of 4kHz.
In any case, good find!
I assume the replacement ECU also fixed a lot of issues? Did you attempt to unseal it and confirm solder joints?
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
post #24 of 24 Old 04-29-2017, 05:29 PM Thread Starter
The ECU was never bad. I had a bad connector in the harness, which I caused when I was probing them while troubleshooting. I opened the connector and pulled the connector out and got it back to the correct shape.
