Gen 4: 2011-2015 moving factory rear set down one - Kawasaki ZX-10R.net
 4Likes
  • 1 Post By Victors
  • 1 Post By scout
  • 1 Post By Snakes709
post #1 of 7 Old 10-18-2017, 11:43 AM Thread Starter
Kawasexy's Avatar
Factory it's in the upper hole position. I'm 6'2"ft only ride street. I don't feel cramped but if there is additional room why not? Any pros and cons or feedback to people that have moved to the lower hole?
Sent from my XT1565 using Tapatalk
Kawasexy is offline
post #2 of 7 Old 10-18-2017, 01:15 PM
Victors's Avatar
Only con is ground clearance if you're leaning way way over
Kawasexy likes this.
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 7 Old 10-19-2017, 07:10 PM
The Pace
scout's Avatar
no problem, you must have the g4, drop the rearsets to the bottom. Thank God for the g4. You will have 'ZERO GROUND CLEARANCE PROBLEM;' assuming you have boot toes on the rearsets; and on even a cracked throttle in super tricky tight turns.
scout is offline
post #4 of 7 Old 10-20-2017, 07:15 PM
Snakes709's Avatar
On the street you wont have issues with going to the bottom. I have mine set on the bottom on my gen 4 for street and then move them to the top at the track since I kept grinding the peg on the ground in the middle of a turn.
2015 ZX10R
2016 ZX14R SE
Snakes709 is offline
post #5 of 7 Old 10-20-2017, 07:30 PM Thread Starter
Kawasexy's Avatar
Anyone have the
torque spec on that bolt?
Kawasexy is offline
post #6 of 7 Old 10-21-2017, 12:23 AM
Snakes709's Avatar
18ft-lbs
2015 ZX10R
2016 ZX14R SE
post #7 of 7 Old 10-21-2017, 07:53 AM Thread Starter
Kawasexy's Avatar
Originally Posted by Snakes709 View Post
18ft-lbs
Thank you sir
Kawasexy is offline
