Lightech Chain Adjuser - Kawasaki ZX-10R.net
 6Likes
post #1 of 27 Old 05-14-2018, 11:06 AM Thread Starter
g-man's Avatar
I have a set of Lightech adjusters for my 2016 Gen5.
Before I start, do I have to get a difference Castle Nut to install this? There is no mention of it in the paperwork.
g-man is offline
post #2 of 27 Old 05-14-2018, 11:21 AM
nope, use the original nut.
10rAlex is offline
post #3 of 27 Old 05-14-2018, 11:23 AM Thread Starter
g-man's Avatar
Perfect! Thanks!
PS, do you still use the stock washer behind the Castle nut?
g-man is offline
post #4 of 27 Old 05-14-2018, 07:37 PM
Originally Posted by g-man View Post
Perfect! Thanks!
You can't use the washer it won't allow the nut to fit. Also, I think the stock nut will scratch the numbers off (or maybe that was the stock washer) - make sure you check that.
You should by an aftermarket castle nut that has a washer fabricated in the cast on the inside (the part of the nut that screws on first), if you know what i mean. You want that washer side so that the nut can be properly seated and torqued.
Lots of places sell those anodized aluminum nuts, that should work - just make sure you get the right size of course. I forget what kind I have but mine is titanium, and is thinner than the stock. Looks to be the same thickness as those anodized ones.
GearsNStuff is offline
post #5 of 27 Old 05-15-2018, 07:51 AM Thread Starter
g-man's Avatar
If you can remember where you got that TI nut, please let me know.
g-man is offline
post #6 of 27 Old 05-15-2018, 11:04 AM
https://tstindustries.com/Gilles-Too...-Axle-Nut.html
The manufacture also makes anodized aluminum nuts just like the one above.
post #7 of 27 Old 05-15-2018, 02:42 PM
Porschenut's Avatar
Wow, that titanium nut is triiiiick! So cool!
Porschenut is offline
post #8 of 27 Old 05-15-2018, 03:06 PM
Yeah it is pretty cool, very happy with it, but for 90 bucks plus the cost of those chain adjusters (in total over 300 dollars), it's a pretty expensive mod that frankly I wish I didn't do, and used the money elsewhere.
But all in all it does look pretty cool, and they definitely work. Bonus too is that when you loosen or tighten the nut, the axle stays in place, unlike the stock adjusters that allow the axle to slide backwards.
post #9 of 27 Old 05-16-2018, 07:48 AM
ddipaola's Avatar
Check out pro-bolt. They've got like every nut/bolt imaginable for these bikes. Titanium, Aluminum, Steel... you name it... the got it.
They've got some sweet colors too.
Titanium, Stainless Steel, Aluminium Fasteners & Motorcycle Bolts | ProBolt
When in doubt... send it!
ddipaola is offline
post #10 of 27 Old 05-16-2018, 09:40 AM Thread Starter
g-man's Avatar
I like this from PRo-Bolt, but can't tell if it locks???
https://www.pro-bolt.com/titanium-ax...-wheel-93.html
g-man is offline
