Gen 5: 2016 -> kit ecu qs/auto-blip issues - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By Lanister
post #1 of 9 Old 03-13-2018, 02:07 PM Thread Starter
Hey guys, wanted to put this out to the community to hopefully help me chase down this gremlin.
I have a 2017 with kit ecu. First ride out on track, I discovered that neither quick shifter or auto-blipper are working. The bike doesn't do anything, no matter how hard I push/pull. Otherwise, the bike runs fine.
I have the following things enabled:
Dash - KQS Up and Down set to ON (indicator is showing both arrows on the bottom right)
ECU Fi Software - Polarity set correctly but I tried both values (4 and 5)
ECU Fi Software - Shift Voltages are default
ECU Fi Software Monitoring Shift Sensor is reporting following values when I operate the shift lever:
At rest: 2.48v
High: 3.89v
Low: 0.70v
So the sensor is talking to the ECU.
Completely puzzled as to what else it might be.
Lanister is offline
post #2 of 9 Old 03-13-2018, 04:43 PM
Newf's Avatar
At rest: 2.48v
High: 3.89v
Low: 0.70v
The std shift times are too short, you’ll need to adjust them to about 50/50/40/20/20 and then if you find the cut is too long you can start to shorten them again. STD map has 5/5/5/5/5 which is too short.
What version software?
Newf is offline
post #3 of 9 Old 03-14-2018, 01:46 PM Thread Starter
I'm running advanced v1.10.
Thanks for heads up on the cut times. I'll look at those for sure.
I do believe I have figured out the problem otherwise. Not 100% sure (haven't tested) yet but it you have to reverse voltages when you go from std shift to gp on those 12 lines. (Shift UP/DOWN Judgement Voltage Low/High). That's 12 different lines in the settings. I assumed that changing "Shifter Sensor Type" from 4 to 5 would make software reverse polarity automatically but it doesn't. You have to do that manually. Again, I haven't confirmed it yet because it's raining but I'm reasonably certain this was the culprit.
Lanister is offline
post #4 of 9 Old 03-14-2018, 05:04 PM
Newf's Avatar
Yes if u change the shift sensor type you have to manually change the up/down judgement voltages. Also, in v1.1 the internal map cut times are different and I’ve had to run all 50/50/50/50/50 to be able to shift.
Newf is offline
post #5 of 9 Old 03-14-2018, 07:48 PM
This. You are correct. GP shift requires swapping the voltages. PITA, but worth it.
CanyonCarver is offline
post #6 of 9 Old 03-19-2018, 12:26 PM Thread Starter
Wasn't too bad and it all worked out. Spent a weekend AFM racing at Buttonwillow and everything ran solid.
CanyonCarver likes this.
Lanister is offline
post #7 of 9 Old 03-19-2018, 01:39 PM
Cool. Hope BW was kind to you. It was damn-near perfect conditions on the 12th.
post #8 of 9 Old 03-19-2018, 07:25 PM Thread Starter
Overall, it was damn close to ideal. Maybe a few degrees warmer would have been a bit better for grip but 60 degrees and light breeze on Sunday was absolutely nothing to complain about. The morning warm-up was a bit sketchy with ambient air in the 40s but everyone managed ok.
Lanister is offline
post #9 of 9 Old 03-19-2018, 10:44 PM
Lol. 40s in the AM are positively balmy for this time of year. February, we started the day at 38. Lots of cold-tire crashes - especially people using warmers. Glad it wasn't too brutal and the shift settings worked out.
