Hey guys, wanted to put this out to the community to hopefully help me chase down this gremlin.
I have a 2017 with kit ecu. First ride out on track, I discovered that neither quick shifter or auto-blipper are working. The bike doesn't do anything, no matter how hard I push/pull. Otherwise, the bike runs fine.
I have the following things enabled:
Dash - KQS Up and Down set to ON (indicator is showing both arrows on the bottom right)
ECU Fi Software - Polarity set correctly but I tried both values (4 and 5)
ECU Fi Software - Shift Voltages are default
ECU Fi Software Monitoring Shift Sensor is reporting following values when I operate the shift lever:
At rest: 2.48v
High: 3.89v
Low: 0.70v
So the sensor is talking to the ECU.
Completely puzzled as to what else it might be.
At rest: 2.48v
High: 3.89v
Low: 0.70v
