Gen 4: 2011-2015 KIBS unit - Kawasaki ZX-10R.net
 2Likes
post #1 of 14 Old 08-18-2017, 03:41 PM Thread Starter
peterd10r's Avatar
Images: 7
KIBS unit
Hi guys,has anyone removed the ABS(kibs)unit off a gen4 before?I checked out the wiring diagram and quickly the wires going into and out of the unit!front and rear sensors,earth,power,ecu and a few others!if anyone has any info regarding removing the unit and ways to stop any faults or codes popping up could you please give me your results be it positive or negative!If I have no information about the process Im going to set myself on a mission to overcome my issue with a non functioning piece of unwanted weight(well that's the idea)
Thanks in advance
Peter
Sent from my iPad using Tapatalk
Helitech likes this.
peterd10r is offline
post #2 of 14 Old 08-18-2017, 11:40 PM
Helitech's Avatar
Subscribed.... now where’s my popcorn?!
peterd10r likes this.
Helitech is offline
post #3 of 14 Old 08-19-2017, 05:53 AM
I'm doing this atm
RBZ10R is offline
post #4 of 14 Old 08-19-2017, 03:46 PM Thread Starter
peterd10r's Avatar
Images: 7
There has to be a way!I need to see what the abs unit is doing in regards to the feeds going into the unit and then out!I have a feeling the only way will be to remove the unit then pull it apart!unless I had a detailed drawing of the internals
post #5 of 14 Old 08-19-2017, 08:49 PM Thread Starter
peterd10r's Avatar
Images: 7
This is involved!a non abs model has a resistor on 1 side of the front sensor then to the ecu and the same for the rear!the abs model has their wiring into the abs unit with a wire going to the ecu!its getting interesting
post #6 of 14 Old 08-20-2017, 11:05 AM
Snakes709's Avatar
I removed my abs system but left the module hooked up and just plugged the holes. From what i read is the bike will go into into limp mode. Im now running brembo 19rcs master cylinder and spiegler lines.
2015 ZX10R
2016 ZX14R SE
Snakes709 is offline
post #7 of 14 Old 08-20-2017, 06:32 PM Thread Starter
peterd10r's Avatar
Images: 7
Yes Snakes I did that a long time ago!I did try Spiegler lines that actually uterlise the abs pump with a RCS19 and Brembo GP4RX calipers and the lever was just like play doh!I ditched the lines to the unit and went from m/c straight to the calipers and my problem was solved!tbh I can't see removing the abs unit happening!
post #8 of 14 Old 08-21-2017, 01:47 PM
Snakes709's Avatar
Thank you! Had that arguement with a dude on our bike group. He was saying you will feel no difference between lines going to the pump vs lines going straight from the mc to the calibers. I never tried replacing the lines with abs still active. So not sure of the feeling. But running the 19rcs and braided lines to the calibers, makes the lever stiff and and very responsive.
2015 ZX10R
2016 ZX14R SE
post #9 of 14 Old 08-21-2017, 10:41 PM Thread Starter
peterd10r's Avatar
Images: 7
Well the Dude is a dud if he is saying there is no difference!Im sure many have commented in the past 2-3years about a shitty brake feel on the gen4 abs models in the past!when I had the abs unit on my bike I had so much trouble trying to bleed them and get a nice firm lever full stop!a lot of times you will get trouble with tiny air bubbles in the m/c but Skydork(I think)brought that to my attention!you have to crack that nipple to be sure but with tlc!I even tapped up the front lever overnight but it still was shit!I good way to put it like they were on Valium,once I went direct to the m/c it was a dream to bleed and the end result was I had complete confidence with what I considered great front stoppies!
post #10 of 14 Old 08-22-2017, 04:59 AM
ABS models have wheel sensors commuteted to ECU via ABS module. Ones on non ABS models commutated to ECU directly but using a simple electrical scheme. If you want to cut off ABS unit (it weight about 2 kg by the way) you need replace harness to nonABS one or make wiring yourself.
rluk is offline
