Gen 2: 2006-2007 How to De-Cat Gen2 with Pics - Kawasaki ZX-10R.net
 7Likes
post #1 of 31 Old 12-10-2012, 07:17 PM Thread Starter
KyleJones's Avatar
First remove your belly fairings and locate the Mid-pipe.
Then remove the 6 allen head screws, i had alotta problem as i went about doing this the lazy way as i did not want to remove the whole exhaust. most of the screws stripped but i was able to get em loose with WD40 and vice grips.
Once removed I used a 1" paddle bit to tear out all of the coil like metal inside the pipes. I did get mine alot cleaner than the pics show.
After i got it back on the bike i then thought to myself well i should have enough room to put a hex headed bolt instead of a crummy allen head. So a trip to fastenall helped. With a 10mm bolt exactly same threads and length! re install those and your good to go. Just thought this may help someone as i completely did not know it was this easy. Almost bought a $130 pipe to do the job. Heck it was maybe $5 to do this? thats if you have to buy a paddle bit and bolts.
Also very sry for how this posted pics this is my first tutorial post.:iamwithst
ID:	167966   Click image for larger version
ID:	167967   Click image for larger version
ID:	167968   Click image for larger version
ID:	167969   Click image for larger version
ID:	167971   Click image for larger version
ID:	167972   Click image for larger version
06 ZX10R
AKA:NINA
KyleJones is offline
post #2 of 31 Old 12-10-2012, 07:39 PM
mackFLY's Avatar
Nice write up. I have been thinking I should do this to mine for a while...pics made it alot better to see what im going after. Thanks!
mackFLY is offline
post #3 of 31 Old 12-10-2012, 07:42 PM Thread Starter
KyleJones's Avatar
Well glad it helped i would def recommend changing to the hex headed bolts, much easier to get a wrench on em and not worry about stripping them
Sent from my iPhone using Motorcycle.com App
06 ZX10R
AKA:NINA
post #4 of 31 Old 12-10-2012, 10:21 PM
zx10rpower's Avatar
Nice bro! So how does it sound???? I have same bike, same exhaust and would like them to be louder. Was gonna de cat and figure out a way to take some of the packing out of the pipes.
zx10rpower is offline
post #5 of 31 Old 12-10-2012, 10:55 PM Thread Starter
KyleJones's Avatar
Sounds a little deeper, havent really taken her outta the shop yet to see how it really sounds. Freakin cold now lol
06 ZX10R
AKA:NINA
post #6 of 31 Old 12-10-2012, 10:56 PM Thread Starter
KyleJones's Avatar
But i would definitely say its louder as well
06 ZX10R
AKA:NINA
post #7 of 31 Old 12-10-2012, 11:04 PM
Shift_Nashville's Avatar
How will it run without a tune for that?
D-CON likes this.
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #8 of 31 Old 12-11-2012, 01:15 AM
zx10rpower's Avatar
Yea brotha its freaking cold in Illinois as well. Went for a quick ride and came back right back home. I'm such a little girl sometimes hahahahaha.
post #9 of 31 Old 12-11-2012, 08:05 AM Thread Starter
KyleJones's Avatar
I am not sure how it will run without a tune, im sure some slight lose in response. When i De cat my 07 R6 i didnt have any tuners and i was really trashy feeling. But i got a map on my PC3 to help on the 10r.
D-CON likes this.
06 ZX10R
AKA:NINA
post #10 of 31 Old 05-09-2016, 12:39 PM
All the bolts on my Cat have worn away, I cant use an allen key on any bolts and my pliers cant turn the bolts either :( Sprayed WD40 and it did not budge.
sarge is offline
