Gen 1: 2004-2005 Hi idle - Page 2 - Kawasaki ZX-10R.net
 6Likes
post #11 of 23 Old 05-17-2017, 05:42 PM Thread Starter
Air ride's Avatar
We put treatment through it this afternoon ( seafoam) then dumped some of my oil and it smelt like gas, cyfend gas out replaced all new she ran nice up until hr ago and it's beginning again. Tattletale signs . Not happy! Are you thinking what I'm thinking? Cuz I really don't want to think that!!!
Air ride is offline
post #12 of 23 Old 05-17-2017, 05:51 PM Thread Starter
Air ride's Avatar
Why does my FI light not come on? It's working , we checked it ?thats what's got me worried my bro says gashiuos oil smell normal if I had a dead plug and treated gas got through the rings but she's firing on all four
I should have checked compression when I had it torn down for plugs
Air ride is offline
post #13 of 23 Old 05-17-2017, 07:22 PM
zx racer's Avatar
Strong gas smell tells me its runing rich. Wat all mods done to the bike?
Sent from my SCH-I545 using Tapatalk
05 ZX-10R SWB.
zx racer is offline
post #14 of 23 Old 05-17-2017, 07:25 PM
zx racer's Avatar
Good way to check and see if all four cylinders are firing properly is start the bike up let it warm up and spray some soapy water on each header pipe if one doesnt steam or dry quick like the others you found your problem.
Air ride likes this.
05 ZX-10R SWB.
zx racer is offline
post #15 of 23 Old 05-17-2017, 09:11 PM Thread Starter
Air ride's Avatar
Sato racing exhaust
Dyno Jet power commander quick shift
Undercut trans
RX-ring drive chain 520
SunStarFront and rear gears 16t front and 41t rear
Bikes been lowered
Air ride is offline
post #16 of 23 Old 05-17-2017, 09:16 PM Thread Starter
Air ride's Avatar
Anybody experience this problem with a power commander v quick shift set up ? I had to change throttle cable assembly to install . It ran problem free long time but I wunder if they go erratic after awhile? This is the first year I've had it on streets , usually we drag
Air ride is offline
post #17 of 23 Old 05-17-2017, 09:17 PM
97grnrs's Avatar
Have you let it run with tank up and watched the lever/ cam for the fast idle adjustment. See if it's moving when the idle goes up. If so thats where to look. Also check for vacuum leaks
97grnrs is offline
post #18 of 23 Old 05-17-2017, 09:58 PM Thread Starter
Air ride's Avatar
97grnrs thank you will do
Air ride is offline
post #19 of 23 Old 05-18-2017, 09:48 AM Thread Starter
Air ride's Avatar
Someone suggested going around idling motor with unlit plummets propane bottle to check for sucking air!
Does that actually work?
Air ride is offline
post #20 of 23 Old 05-18-2017, 10:22 AM Thread Starter
Air ride's Avatar
Air ride is offline
