Gen 5: 2016 -> Help with figuring what broke - Kawasaki ZX-10R.net
 3Likes
  • 1 Post By tdh
  • 1 Post By bun1t
  • 1 Post By MPac
post #1 of 10 Old 11-18-2017, 02:53 PM Thread Starter
MPac's Avatar
I?ve got to get a picture, but I?ll try to explain the best I can until then, recently the right side fairings blew off my bike and broke some stuff. I believe it?s emission parts which if it is that?s cool because I?ve already been flashed and will remove it. There is a rectangular canister which I?m assuming is a charcoal canister for the emission, there is a vacuum that says tanks, then on the there is a vacuum fitting that has 2 ports with an electrical connection on it, the one port broke off and there is a spade connector not hooked to anything. Like I said this is all on the right side of the bike. What parts are those that broke? Are they part of the emissions? Can I remove them, there is no FI light, it rides fine. I will get a picture soon.
MPac is offline
post #2 of 10 Old 11-18-2017, 03:22 PM
tdh
tdh's Avatar
Yes all of what you describe is related to the evap charcoal can and can be removed. Removing the motor will throw a code if you don't have that disabled in your ECU flash. The 2 vacuum lines connect to the bottom of the tank. I pulled those hoses and canister out of mine the day I got it. Do not plug the lines. Make sure to replace with proper vent lines in the bottom of the tank. If you plug the lines you will collapse your tank when the fuel pump pumps the fuel out. Don't ask me how I know.
scout likes this.
tdh is offline
post #3 of 10 Old 11-18-2017, 04:20 PM Thread Starter
MPac's Avatar
Yes the pairs and all that has been disabled in the flash. So do I just loop those lines to each other or what?
MPac is offline
post #4 of 10 Old 11-18-2017, 05:03 PM
tdh
tdh's Avatar
I just ran tubes from the vent nipples on the bottom of the tank to a Y to another hose that just vents down into the belly pan.
tdh is offline
post #5 of 10 Old 11-18-2017, 08:17 PM Thread Starter
MPac's Avatar
The one that broke on the nipple pulls a vacuum, where does that run to and how do I route it?
MPac is offline
post #6 of 10 Old 11-19-2017, 09:12 PM
tdh
tdh's Avatar
Can you post a picture?
tdh is offline
post #7 of 10 Old 11-23-2017, 07:34 PM
The Pace
scout's Avatar
After quite a few miles on two g4's, I can say that one thing Kawa got right was the plastic.
something you did.
scout is offline
post #8 of 10 Old 11-24-2017, 09:02 AM
bun1t's Avatar
something you did.
I beg to differ on that one. I hate the flimsy tabs on the gen 4. The tank panel tabs under the seat and the tail section side panel tabs are especially weak. Most ZX10's I come across are broken or cracked in those places.
However the front end is decent and I will agree user error on that.
scout likes this.
bun1t is offline
post #9 of 10 Old 11-24-2017, 06:33 PM Thread Starter
MPac's Avatar
I donít see how it was user error, almost every ride Iím checking the fasteners on the fairings, nothing was over tightened, nothing was loose.
scout likes this.
MPac is offline
post #10 of 10 Old 11-24-2017, 07:45 PM
The Pace
scout's Avatar
off topic, but I really really wish the super bike engineers will come up with a quick head light bulb replacement system.
scout is offline
