Head from gen 5 on gen 4 - Kawasaki ZX-10R.net
post #1 of 7 Old 08-22-2017, 08:07 AM Thread Starter
Anyone done this? Is it a straight swap? Just wondering if there will be any benefit from that performance wise
ypyk_xau is offline
post #2 of 7 Old 08-22-2017, 08:44 AM
Carlos76's Avatar
I have not done it. No straight swap, because throttle bodies are different, TB is round and smaller diameter, meaning at least adapting boots is needed. It could work, head gasket is same part number, I would guess that all cam chain offsets could be same too (fact that race cam part number is same). Piston to valve clearance should be checked and degrees checked to be good.
Sure performance will increase after good tuning. When you need performance then deck the head and use think gasket too.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #3 of 7 Old 08-22-2017, 12:09 PM
mpp12's Avatar
same HG, so I imagine that if you put everything else from a gen4, there will be no problem
mpp12 is offline
post #4 of 7 Old 08-22-2017, 04:52 PM
Carlos76's Avatar
What about valve "pockets" in piston?
They could possibly be bigger because of bigger exhaust valves and deeper to accommodate smaller gen5 cam degree numbers.
Carlos76 is offline
post #5 of 7 Old 08-22-2017, 09:47 PM
mpp12's Avatar
He needs to measure ptv clearance
Enviado desde mi iPhone utilizando Tapatalk
mpp12 is offline
post #6 of 7 Old 08-23-2017, 03:53 AM
Carlos76's Avatar
Yes.
Having no idea what the lateral clearance to piston "pocket" could be. Traditional ptv check not showing it, use clay for example.
Carlos76 is offline
post #7 of 7 Old 08-23-2017, 06:14 AM
mpp12's Avatar
Just make the valve pockets same as valve. A dremel and 15 min is done
Enviado desde mi LG-D855 mediante Tapatalk
mpp12 is offline
