Gen 5: 2016 -> GP Shift 2016 ZX10R: A Dirty Mod... - Kawasaki ZX-10R.net
 39Likes
post #1 of 232 Old 01-01-2016, 11:16 PM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
UPDATED: 2016 zx10R parts diagram and numbers
https://www.kawasaki.com/Parts/Parts...2016/ZX1000SGF
If the link disapear... www. kawasaki.com/Parts/ PartsDiagrams /2016/ZX1000RGF
Ok I am in the garage swapping parts from my 2011/Gen 4s and the 2016/Gen 5 to test and see what fits (so i can buy used Gen 4 stuff to put on the Gen 5).
1st, The Gen 4 Rear-Sets bolt directly up to the Gen 5. (I used my Vortex from my Gen 4 Race bike).
Top of my list of Mods is going to GP shift/Reverse shift. With the stock rearsets, and shift arm, this looks impossible like way back when the Gen 4 came out.
The huge Quick Shifter Housing and the recessed in shift arm, makes the swap to GP shift impossible. The shift arm is too long and set too far back and the QS housing shape is too thick.
How I made it work:
In the picture below you will see
Gen5 ......Gen 4.......Gen 3
Shift Arm.
Again you will have to use a Gen 3 (08-2010) Shift arm.
Next I took the Vortex rear-sets from Gen 4.
You will have to do some playing around with the Gen 5 shift ROD.
Install the Gen 3 shift ARM, take the Gen 5 shift ROD from the right /back side and relocate it to the front side.
(you will have to do this because the Gen 3, shift ARM is has a MALE end Thread....while the Gen 5 shift ARM have a FEMALE end thread.
The set up is like this...and the pictures below will help.
Gen 3 shift ARM...connected to short Gen 5 shift ROD...connected to KQC (kaw quick shifter)....connected to FEMALE thread end Vortex shift LINKAGE (connects to shift LEAVER).
The Gen 4 vortex Rear-sets came with a MALE and FEMALE adaptable shift LINKAGE....that is connected to the shift LEVER...
I had other options like cutting and making another short shift rod to adapt the GEN 3 shift ARM to the KQS unit, but it would have been hella long.
Also, you will need to unplug the KQS and re-fish the wire so you have enough line to shift with out pulling on the wire.
I zip tied the wire down.
It is real close ...the KQS to the shift Lever and the KQS to the frame.
Ill update this if I forgot to mention something.
I read that the KQS is not a push/pull type...then again I have heard its both...I will test out another day.
ID:	350874   Click image for larger version
ID:	350882   Click image for larger version
ID:	350890   Click image for larger version
ID:	350898   Click image for larger version
ID:	350914   Click image for larger version
ID:	350922   Click image for larger version
ID:	350930   Click image for larger version
ID:	350938   Click image for larger version
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #2 of 232 Old 01-01-2016, 11:16 PM Thread Starter
Vonstallin's Avatar
Images: 16
more pics...
and a video I made...real quick with some of the Multi function Dash electronics.
http://www.youtube.com/watch?v=OvahE...ature=youtu.be
ID:	350954   Click image for larger version
ID:	350962   Click image for larger version
ID:	350970   Click image for larger version
ID:	350978   Click image for larger version
post #3 of 232 Old 01-01-2016, 11:23 PM Thread Starter
Vonstallin's Avatar
Images: 16
Other pictures...
ID:	351010   Click image for larger version
ID:	351026   Click image for larger version
ID:	351034   Click image for larger version
ID:	351042   Click image for larger version
ID:	351058   Click image for larger version
ID:	351066   Click image for larger version
ID:	351074   Click image for larger version
ID:	351082   Click image for larger version
stage5 and Nofoot like this.
post #4 of 232 Old 01-02-2016, 12:33 AM
So does the quick shifter still work now that the switch is pulling instead of pushing, or vice versa from how it originally was?
Boxtradamus is offline
post #5 of 232 Old 01-02-2016, 01:54 AM
Always On Mod
Animal11's Avatar
Good job!
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #6 of 232 Old 01-02-2016, 02:03 AM Thread Starter
Vonstallin's Avatar
Images: 16
I wrote this before doing the Brake rear-set side....that Took WAY longer trying to make it fit the Vortex rear-set.
Only because of the extremely short hose on the ABS models. This should not be an issue on NON-ABS models.
Just so happen my rear brake MC banjo bolt was finer tight....smh....but in the end I had to unscrew it half way up, then line up all the other adjustments then bolt them down then the banjo bolt last...it is stretched super tight.
I think I am going to shim my shock about 3mm to 5mm , and when I do that I am going to see if there is any way to move part of the ABS distribution box that is bolted to the frame near rear brakes to give the rear some slack.
ID:	351146   Click image for larger version
ID:	351154   Click image for larger version
ID:	351162   Click image for larger version
ID:	351170   Click image for larger version
post #7 of 232 Old 01-02-2016, 02:06 AM Thread Starter
Vonstallin's Avatar
Images: 16
Not sure...
I hear everything from it can be done via ECU , to its push or pull only to its both push and pull...
I will test it out.
Bazzaz new shifter are both...and I love it. It works in GP shift or standard.
Originally Posted by Animal11 View Post
Good job!
Thanks ... cant wait to ride it now...
standard shift was throwing me off.
But this is a dirty mod....
shit was hard...probably the hardest ever. Im glad i have so many spare parts over the years.
post #8 of 232 Old 01-02-2016, 08:44 AM
mpp12's Avatar
I wonder about the exhaust of the gen5 will fit a gen4?
mpp12 is online now
post #9 of 232 Old 01-02-2016, 08:56 AM
renais's Avatar
Beautiful Bike
renais is offline
post #10 of 232 Old 01-03-2016, 12:02 AM Thread Starter
Vonstallin's Avatar
Images: 16
Looks like the rear wheels fit also....Checked the Gen 4 wheels with the Gen 5...
I figured they fit...but always better to be certain...
Also installed cross drilled rotor
ID:	351290   Click image for larger version
ID:	351298   Click image for larger version
ID:	351306   Click image for larger version
ID:	351314   Click image for larger version
ID:	351330   Click image for larger version
ID:	351338   Click image for larger version
BAKWHEELTANGO likes this.
