Gen 5: 2016 -> GP Shift 2016 ZX10R: A Dirty Mod... - Page 2 - Kawasaki ZX-10R.net
 39Likes
post #11 of 232 Old 01-03-2016, 12:11 AM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
had all the bikes lined up
ID:	351354   Click image for larger version
ID:	351362   Click image for larger version
ID:	351370   Click image for larger version
ID:	351378   Click image for larger version
ID:	351394   Click image for larger version
ID:	351402   Click image for larger version
ID:	351410   Click image for larger version
ID:	351418   Click image for larger version
mr_honez and stage5 like this.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #12 of 232 Old 01-03-2016, 09:51 AM
jr0065's Avatar
Images: 18
Send a message via Yahoo to jr0065
Originally Posted by Boxtradamus View Post
So does the quick shifter still work now that the switch is pulling instead of pushing, or vice versa from how it originally was?
What he said... Does the quick shifter work now in GP?
Gen 5 ZX-10R
jr0065 is offline
post #13 of 232 Old 01-03-2016, 10:15 AM
Supercharged Mod
I have a funny feeling that KQS won't work with the shift rod sensor reversed and (unless Kawasaki has fixed this, which they might have ...) there's no way to change it without reflashing the ECU. The sensor is not a simple switch (like the various Dynojet etc aftermarket switches are), it is a strain gauge that actually measures how much force is being applied and in which direction.
The H2 has the logic for reverse shift pattern in the ECU but you have to reflash to enable it ... I am hoping Don Guhl will come to the rescue.
SkyDork likes this.
GoFaster is offline
post #14 of 232 Old 01-03-2016, 10:49 AM
dricked's Avatar
Wow! So far I can see where I wouldn't have to spend around $3000 to build a bike provided the linkage isn't a must need item.
I'm really interested in what the front fork cartridge kits are going to be like with the new forks.
dricked is offline
post #15 of 232 Old 01-03-2016, 11:40 AM
SkyDork's Avatar
It's not going to just work. The ECU has to know which direction is being activated in. While the switch may be bidirectional, the ECU will think you're trying to down shift and nothing will happen. I'm sure it will be corrected by reflash soon enough, but until then the quick shifter won't work like that.
#WordCrimes
SkyDork is offline
post #16 of 232 Old 01-03-2016, 12:20 PM
tdh
tdh's Avatar
Kawasaki could have programmed it work in either direction in the stock ECU. Since they don't do auto blip downshifts on the stock ECU out of the box they could have programmed the push and pull to perform the same function (similar to the Bazzaz QS). I personally don't care since I run standard shift but that would make life easier for those who want to run GP shift.
tdh is offline
post #17 of 232 Old 01-03-2016, 12:21 PM
SkyDork's Avatar
We'll know for sure soon enough.
tdh likes this.
#WordCrimes
SkyDork is offline
post #18 of 232 Old 01-03-2016, 01:23 PM
Always On Mod
Animal11's Avatar
The menu options I saw were kqs level 1 or off. There may be a way to get into a deeper menu to change the direction? Or depending what the race dongle gives you access to it may open up more options. I'm sure Woolich is digging into all that as we speak.
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #19 of 232 Old 01-04-2016, 01:45 AM
theatiss's Avatar
Porn bike collection... Nice youtube channel ...Subscribeddddddd
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #20 of 232 Old 01-04-2016, 02:11 AM Thread Starter
Vonstallin's Avatar
Images: 16
Ill probably end up selling my 2011/Gen 4 some time this season...
I have the same list of equipment as my race bike...
I am going to see if one of my friends want it, because Id be giving away soooo much stuff.
Ill wait until I can get use to the 2016 first tho.
Also...
I measured the Gen 4 exhaust opening (deleting the cats/boom box) and the Gen 5....it looks as though they are the same size.
It was too much shit to take apart this weekend..but I plan on finding out.
If so, I am putting on a Gen 4 slip on and save some money....
The only issue I can see is the mounting bracket. The Gen 4 has 2 position holes and most shorty exhaust brackets use one or the other to hold the can up.
So with the Gen 5 only having one hole and not in the same spot as the Gen 4...you might have to drill an additional hole or make a bracket.
I read somewhere that Kaw put additional catalytic converters in the header pipe on the Gen 5....is that true?
I remember the Gen 3 had that done....I had mines cut out.
