Gen 1: 2004-2005 Generator repair bulletin - Page 4 - Kawasaki ZX-10R.net
 2Likes
post #31 of 245 Old 09-13-2012, 10:52 PM
Originally Posted by mikeymeyagi View Post
my stator windings died and im having no luck finding a C gear 05 generator, and i dont need this thing coming apart and wrecking my motor. i think im going to have no choice but to re use the 04 style generator and change the parts they reccomend and hope for the best i guess. prior to the stator dying i really didnt notice any weird noises but then again i havent taken it completely apart yet as i was trying to find the 05 style generator. hopefully nothings worn out when i get it apart
Witch kind of noise? Know? Metal whispering?
spirity is offline
post #32 of 245 Old 09-13-2012, 10:58 PM Thread Starter
Nightmist's Avatar
for me its a rattle noise, can hear it on short burst of the throttle in neutral
Nightmist is offline
post #33 of 245 Old 09-13-2012, 11:00 PM
bluedevil's Avatar
Originally Posted by GoFaster View Post
I only used Bikebandit to get a quick price. Best bet is to order them from the dealer to get the right ones.
not sure why....if the same part # should be the "right" ones if you order from a place like Bikebandit, Ronayers or someone else....not sure but believe they all come from the same warehouse at the end of the day.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #34 of 245 Old 09-14-2012, 08:53 AM
Mine does that and my engine is 017xxx! It means that I'm driving a time bomb?
spirity is offline
post #35 of 245 Old 09-14-2012, 09:27 AM Thread Starter
Nightmist's Avatar
most likely yes. and this is why i posted up the bulletin so you can try to repair it before it blows up
if you check the first page on the bulletin, it will tell you that all engines before 018111 are eligible for that repair, i would atleast open if up and check that you have the right washers according to the bulletin and that you'r generator does have the right clearance, or... just order the parts you need and have at it, cant make things worse than it allready is
post #36 of 245 Old 09-14-2012, 09:55 AM
I will order the parts!
Could you please sent the PDF to my mail...
spirity@happyhippo.com
Thx
spirity is offline
post #37 of 245 Old 09-14-2012, 10:17 AM Thread Starter
Nightmist's Avatar
Thx
You have mail...
post #38 of 245 Old 09-15-2012, 05:08 PM
You have mail...
Really thanks!
If I understand correct, this increase the oil flux (0,2mm) and reinforce the spacers, right?
And how about use oil 30w10?
Regards
spirity is offline
post #39 of 245 Old 09-17-2012, 11:57 AM Thread Starter
Nightmist's Avatar
Really thanks!
Regards
when it comes to oil, i guess i would just go with the 10w-40.
as to what this repair does, as far as i can see it just makes sure that everything sits as should (changing the 1mm spacer for the 1.2mm) aswell as checking the clearance so you dont get any vibrations and unwanted movement in the generator.
post #40 of 245 Old 09-22-2012, 10:26 AM
skidooboy's Avatar
where do you find the motor numbers? ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
