Gen 1: 2004-2005 Generator repair bulletin - Page 3 - Kawasaki ZX-10R.net
 2Likes
post #21 of 243 Old 09-13-2012, 11:01 AM Thread Starter
Nightmist's Avatar
well i guess it all depends on what people regard as weird noises.. i had another kawa mechanic listen to it and telling me that mine was perfectly normal cam chain rattle and that they all did that, that diddnt really sit well with my experience with engines so i got a stetoscope and started listening, i can clearly hear the rattle coming from the generator and not the cam chain tensioner, i might just have over sensitive ears but time will tell when i get the fucker out.
Best of luck to you tho
Nightmist is offline
post #22 of 243 Old 09-13-2012, 11:19 AM
yeah i listened to mine with a stethoscope too right on the generator shaft and theres a little rattle but its not crazy like things are getting ready to self destruct...
2004 ZX10R with a little extra kick from a Garrett GT28RS
mikeymeyagi is offline
post #23 of 243 Old 09-13-2012, 11:37 AM Thread Starter
Nightmist's Avatar
well then i guess i would go ahead with that repair aslong as you can hear the rattle, atleast take it out and check that you have the 1.2mm spacer instead of the 1mm one, and check the clearance to see if you need to shim it up to spec
post #24 of 243 Old 09-13-2012, 12:07 PM
for sure.... post what you find when you get yours apart, im prob gonna order the full set of shims to be safe...
post #25 of 243 Old 09-13-2012, 12:16 PM Thread Starter
Nightmist's Avatar
Will do, i ordered all the shims and gaskets for mine so will do this as soon as i can, if you do order it would you post the cost of it? would be nice to see price range worldwide.. i live in norway so it will probably be a tad more expencive over here.
post #26 of 243 Old 09-13-2012, 12:27 PM
Supercharged Mod
On Bikebandit those shims are something like $3 each. Dirt cheap in parts, just some labour involved, plus it gives a good chance to do a thorough inspection of the generator assembly in case there are any issues. I'm curious to see what the innards of mine are like after 70,000 km.
GoFaster is offline
post #27 of 243 Old 09-13-2012, 12:52 PM Thread Starter
Nightmist's Avatar
do they have the silver plated treatment like the upgraded kawa ones do?
post #28 of 243 Old 09-13-2012, 02:20 PM
Supercharged Mod
I only used Bikebandit to get a quick price. Best bet is to order them from the dealer to get the right ones.
GoFaster is offline
post #29 of 243 Old 09-13-2012, 02:32 PM Thread Starter
Nightmist's Avatar
ended up at 100$ for all the spacers/washers at the local shop over here, sendt them another mail about the gaskets aswell but dont have a reply on that yet.
post #30 of 243 Old 09-13-2012, 03:25 PM
yeah ill let you know the price, i need to replace my stator and i found one on ebay for 144 shipped. gotta call the dealer and get the spacers though
