Gen6 zx10r H2R killer build - Page 5 - Kawasaki ZX-10R.net
 62Likes
post #41 of 207 Old 10-14-2015, 03:55 PM
Send a message via Skype™ to Nofoot
Originally Posted by thundercoupe9 View Post
I am going to use 2nd gen cables, I am not sure if they're longer than 1st gen or not.
I don't remember what epoxy that I used, I did it 3 years ago on my 2nd gen.
Tps connector is different, so I'll cut the 1st gen connector off, extend it, and hook up 2nd gen tps connector, the wire color code should be Identical.
Nice one... Thank you for the info :)
Nofoot is offline
post #42 of 207 Old 10-15-2015, 05:18 PM Thread Starter
thundercoupe9's Avatar
was mocking up tail section.
ID:	342746   Click image for larger version
thundercoupe9 is offline
post #43 of 207 Old 10-15-2015, 06:57 PM
Somefun's Avatar
Looks good man keep up the great work! 👌🏻
Spegler SS lines with EBC HH pads front n rear along with Brembo M4 calipers, EBC front and rear rotors, Brembo Radial MC & Brake Levers, Sato rear sets, BST carbon fiber wheels, Pirelli Diablo Super Corsa SP, Ohlins TTX EC Rear Shock, revalued steering damper, leatec gas cap, Don Guhl Reflash, Akropovic & linked pipe. HM quick shifter,green silicon hoses, Shoria battery and shimmed the rear 5mm and lastly (for now) an EBC Kevlar race clutch & HD springs, Vortex case covers.
Somefun is offline
post #44 of 207 Old 11-17-2015, 04:56 PM
Any updates ?
Nikobx is offline
post #45 of 207 Old 11-20-2015, 11:18 AM
Grease Monkey Bandit
AirborneMechanic's Avatar
Whys this thing so short? :D
"Homewrecker" Gen3 custom build by ZX-SIK-R in progress.... check the build thread: http://www.zx-10r.net/forum/f28/airb...ad-140226.html
AirborneMechanic is offline
post #46 of 207 Old 11-20-2015, 11:32 AM
because gen 1's had a short wheel base? made turn-in a lot easier.
Cageconvert is offline
post #47 of 207 Old 11-20-2015, 01:04 PM
I was being sarcastic. I can clearly see its on a stock arm. Just waiting for this guy to build a drag bike ;)
post #48 of 207 Old 12-16-2015, 07:41 PM Thread Starter
Because doesn't have a flashed ECU, won't go very fast
post #49 of 207 Old 12-16-2015, 07:43 PM Thread Starter
Putting 2nd gen itbs on the bike, had to change tps plug and extend the harness. Secondaries were removed and holes epoxied to eliminate and leaks under boost.
post #50 of 207 Old 12-17-2015, 05:06 AM Thread Starter
Short video with ITBS measurements and modification to the wiring harness.
theatiss likes this.
