Gen6 zx10r H2R killer build - Page 3 - Kawasaki ZX-10R.net
 62Likes
post #21 of 207 Old 09-06-2015, 05:55 AM Thread Starter
thundercoupe9's Avatar
Originally Posted by Nofoot View Post
So that's going to be a "Frankenstein" bike as well... looking forward to see how it will turn out!
Pretty much gen1+gen2+gen3 parts.......aka gen6
theatiss likes this.
thundercoupe9 is offline
post #22 of 207 Old 09-06-2015, 08:22 AM
evilaugust's Avatar
Sounds cool. I'm in.
evilaugust is offline
post #23 of 207 Old 09-07-2015, 06:15 PM
motoboy's Avatar
Yeah sound good will keep a eye on this one for sure......
motoboy is offline
post #24 of 207 Old 09-08-2015, 12:54 AM
theatiss's Avatar
subscribed
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #25 of 207 Old 09-11-2015, 06:34 PM Thread Starter
finally putting the clutch in, going to pull the oil pan off, drill and tap it for oil return line and work on the feed line next.
ID:	339506   Click image for larger version
post #26 of 207 Old 09-12-2015, 01:54 PM
SpazOnaZX's Avatar
If you're using the clutch cover for a return line make sure you get the whole line below the bottom of the CHRA.... or you'll need a scavenge pump/check valve. You an use the oil pan on a gravity feed if you use a large enough line... I used a -10 and it works like gangbusters. :)
SpazOnaZX is offline
post #27 of 207 Old 09-12-2015, 09:55 PM Thread Starter
Thanks man.
post #28 of 207 Old 09-17-2015, 02:29 PM Thread Starter
wrong link
post #29 of 207 Old 09-22-2015, 09:43 PM Thread Starter
post #30 of 207 Old 10-02-2015, 09:00 PM Thread Starter
Removing more stock parts that won't be getting used, almost 7lbs.
