Gen6 zx10r H2R killer build
42K views 212 replies 31 participants last post by  thundercoupe9
#1 · (Edited)
Going to start working on my new project, Gen1 zx10r. Goal is simple, make it as fast as possible. It's going to be combination of gen1+gen2+gen3 parts..................aka Gen6.
I am starting with a gen1........... time to make it fly.:badteeth:
#9 ·
subscribed
#26 ·
If you're using the clutch cover for a return line make sure you get the whole line below the bottom of the CHRA.... or you'll need a scavenge pump/check valve. You an use the oil pan on a gravity feed if you use a large enough line... I used a -10 and it works like gangbusters. :)
#34 ·
To be able to do a burn out, I have to hold the front brake and then go WOT, which is kind a hard to do with 1 hand. I had 3 options. Option 1 is a thumb throttle. Option 2 is to put a line lock. And option 3 was to move brake lever to the left clip on, so I am able to work the brake with my left hand and work the throttle with my right hand.
