Gen 5: 2016 -> Gen5 rear suspention link info needed - Kawasaki ZX-10R.net
 23Likes
post #1 of 139 Old 01-03-2016, 09:25 AM Thread Starter
Carlos76's Avatar
I'm tempted to find out gen5 rear suspension linkage geometry. Hope someone here in forum owning gen5 has shock out and would measure link plate and dogbone dimension. You could maybe get measurements by pressing a piece of carton against linkage bolts (with shock in place) and measure from dent traces.
I attached an image and need measurements A, B, C and D.
Having these measurements I could do some calculations comparing it to gen4 stock and aftermarket link. This could give us first clues if stock link is now optimal for track use, is it closer to gen4 aftermarket or gen4 stock (high ratio, not optimal for racing). And what Ohlins high speed valving to use. Did read here that someone already fitted Ohlins shock on Gen5 and guess shock length is same with gen4, then probably gen5 mounting points have not changed.
Big Daddy and Vonstallin like this.
Carlos76 is offline
post #2 of 139 Old 01-09-2016, 07:05 AM Thread Starter
Carlos76's Avatar
Bump. Anyone having possiibility to measure gen5 linkage dimentions?
Carlos76 is offline
post #3 of 139 Old 01-09-2016, 08:40 AM
mpp12's Avatar
Interesting
mpp12 is online now
post #4 of 139 Old 01-09-2016, 10:58 AM
Big Daddy's Avatar
Images: 38
I suspect at some point a Gen5 owner will assist with measurements, be patient.
Big Daddy is offline
post #5 of 139 Old 01-09-2016, 11:08 AM
mpp12's Avatar
There is a guy in FB that will strip the bike for racing...
contact him. Think he is in some group
mpp12 is online now
post #6 of 139 Old 01-13-2016, 03:26 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
The gen 4 shock is longer than the Gen 5.....that is what I read.
Measuring the plate is easy but the dog bone isnt unless i take it off...
I also have Gen 4 Race Links 3.5 and 4.0 from MSS Colechester, along with stock The Gen 5 links look way different to me.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #7 of 139 Old 01-18-2016, 01:14 PM Thread Starter
Carlos76's Avatar
I think gen5 link is good for track junkie. Without having numbers, but looking at attached image, I would say two statements.
a) Link is more linear like text says and can see that angle from swingarm bolt to shock bolt is more upright (link rotation causes more initial spring movement).
b) Link ratio must be lower than gen4 (closer to aftermarket ratio, since measurement A/B ratio is better).
Ohlins has already shock (KA364) for 2016, but spring spec. unknown. I estmate when that Ohlins spring is now below 110N then we may not need link replacement.
Carlos76 is offline
post #8 of 139 Old 01-18-2016, 01:27 PM
Vonstallin's Avatar
Images: 16
what model number is the Gen 4 Ohlins TTX?
KA364 for Gen 5 I see you wrote....
For my two Gen 4s I ordered the same Ohlins TTX...but they came with two different model numbers.
I noticed that the adjustment knobs (black and gold) where different shape, but everything else was the same.
when I sell my street Gen 4 I am taking the Ohlins off. I heard the Gen 4 shock is either shorter or longer then Gen 5.
I also wonder if Ohlins making a plug in electronic shock for the Gen 5 like the Gen 4?
post #9 of 139 Old 01-18-2016, 01:34 PM Thread Starter
Carlos76's Avatar
I'm still intrested to know gen5 dogbone length dimention.
When it is longer than gen4 bone, then I will use it for gen (with custom fabricated plates).
Carlos76 is offline
post #10 of 139 Old 01-18-2016, 02:05 PM Thread Starter
Carlos76's Avatar
[/IMG]
KA364 according to www.ohlins.EU
If it turns out that KA364 uses from factory a spring 95...105, then it is a hint that gen5 link ratio is similar to aftermarket link. In this case I would wait selling your Ohlins (gen4) shock, if it is valved for aftermarket link and you weigth, then just install it on gen5.
If gen5 shock is longer, then just add clevis shim to balance. If it is shorter and gen4 Ohlins will be too long, then Ohlins must be opened and made shorter by adding washers below topout spiring.
Carlos76 is offline
