Gen 5: 2016 -> Gen5 rear suspention link info needed - Page 4 - Kawasaki ZX-10R.net
 23Likes
post #31 of 139 Old 03-10-2016, 07:03 AM Thread Starter
Carlos76's Avatar
LDH, you replied to CanyonCarver (about using his gen4 Kyle valved TTX on gen5) that his compression spec is "way higher".
Here Geometry on the 2016 ZX10r post number #55 says that gen5 link ratio is 2.095.
If this number is true, then there is no significant difference between Kyle 2.15 ratio. Based on this fact, I would say CanyonCarver could be just fine with his (Kyle valved) TTX bolted on gen5 with gen5 stock link.
His shock in gen5 should work the same as in his gen4.
If a spot-on Kyle valving and spring recommendation are way different than Ohlins TTX for gen5, then why did Ohlins go that soft? Did they have street use in mind with factory standard spec?
Carlos76 is offline
post #32 of 139 Old 03-21-2016, 05:50 PM Thread Starter
Carlos76's Avatar
Bump. Can anybody measure Gen5 dogbone length. Dimention D, see picture at post #1.
Carlos76 is offline
post #33 of 139 Old 04-01-2016, 05:20 PM Thread Starter
Carlos76's Avatar
Originally Posted by rafa View Post
If the Gen 5 link is similar to the race links for the Gen 4 might be worth a while using stock gen 5 link on the gen 4 for racing.
This is why I need gen5 bone length measurement!
Anybody willing to measure damn thing?
Plus-minus 2mm would be enough.
Don't want to order it just to find out it's not much longer.
Carlos76 is offline
post #34 of 139 Old 04-01-2016, 06:52 PM
I have a gen 5 and would happy to measure. What measurements do you want?
gsxrvette is offline
post #35 of 139 Old 04-01-2016, 07:00 PM
I got 145mm from center of the screw to center of the screw on my stock dogbone on the gen 5. That is within 1mm or so. I could get it closer if I pulled it off the bike
Carlos76 likes this.
post #36 of 139 Old 04-02-2016, 05:00 PM Thread Starter
Carlos76's Avatar
Thank you gsxrvette. That measurement is sweet for designing a race link.
Carlos76 is offline
post #37 of 139 Old 04-02-2016, 07:21 PM
Let me know if you need any other info. 👊👊
post #38 of 139 Old 04-18-2016, 05:21 PM
Squid wannabe
rafa's Avatar
This might help someone.
Lanister and Carlos76 like this.
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #39 of 139 Old 04-18-2016, 06:16 PM Thread Starter
Carlos76's Avatar
Ladies and Gentlemen!
Thanks to Vonstallin, Gsxrvette and Rafa I think that Gen5 link is roughly "MSS3.9"
One small warning if someone installs it on Gen4: Please measure rear heigth before/after and adjust with shock shim when Gen5 link should change rear heigth.
Lanister likes this.
Carlos76 is offline
post #40 of 139 Old 04-18-2016, 10:17 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
One small warning if someone installs it on Gen4: Please measure rear height before/after and adjust with shock shim when Gen5 link should change rear height.
I had someone told me the Gen 5 link was close to the 4.0 MSS links
(that i have for sale in the parts page).
I heard it might be slightly better, but not worth it...and Gen 5 is good enough.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
