Gen 5: 2016 -> Gen5 rear suspention link info needed - Page 3 - Kawasaki ZX-10R.net
 23Likes
post #21 of 139 Old 02-09-2016, 03:38 AM Thread Starter
Carlos76's Avatar
Originally Posted by Vonstallin View Post
What are Kyle valving or Race links?
I only knew of MSS and Attack Kawasaki Race Links.
KyleUSA sells it's link, it is good one, many racers and tuners use it too.
Kyle valving is shim stack configuration inside TTX what they install to match their link and rider ass. Normally tuners don't publish their stack config (high speed valving shims used).
Carlos76 is offline
post #22 of 139 Old 02-09-2016, 06:19 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Ah ok.
I did not know they matched valving to race links.
I am sending Thermosman my TTX to get revalved...he has my 4.0 links measurements, but I may send them also.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #23 of 139 Old 03-04-2016, 05:30 PM
LDH
LDH's Avatar
I compared the Spec Sheets for the KA360 (Gen4) to the KA364 (Gen5) and the only 2 things that really stand out are the way lower start rate on the KA364 using the 90Nm spring for a 160-180lb rider (versus the 110Nm for the Gen 4) and the rebound spec has been reduced one setting. So basically a spring swap and a shim stack change and you can fit an otherwise unadulterated KA340, KA358 or KA360 for the Gen4 bike onto a Gen5 model. Might also have to rearrange the hydraulic adjuster collar and hose to a better positon...
There are a few other small things with spacers, stroke length and topout spring etc, but I don't personally think those particular changes will make much difference in the grand scheme of things for most riders.
LDH is offline
post #24 of 139 Old 03-04-2016, 05:56 PM
Vonstallin's Avatar
Images: 16
good to know.
post #25 of 139 Old 03-04-2016, 06:23 PM
CanyonCarver's Avatar
So for my KA931 that was revalved to work with the Kyle 5% link, should I be able to bolt that into the Gen5 bike and have it work well with the stock link? And would I need to do anything else, like the 8mm shim I have on the Gen4?
I plan to buy the newer generation of the TTX, but until I can sell off some Gen4 parts to finance it, I'm inclined to bolt in the KA931 in the meantime, if it'll work okay.
CanyonCarver is offline
post #26 of 139 Old 03-04-2016, 06:28 PM
LDH
LDH's Avatar
I would venture to say No. You would be pretty close on the Rebound spec, but the Compression Valving is way higher than what is spec'd as standard. I mean might be worth a try for grins and giggles, but as fast as you are, you need accurate specs to maintain the composure and attitude of the bike.
LDH is offline
post #27 of 139 Old 03-04-2016, 06:40 PM
Shit. Wasn't the answer I was hoping for, but your honesty is always appreciated. Guess I'll ride the Gen4 one last time on the 14th and start tearing it down and selling off some parts so I can get some new toys from you guys. Hope to see you out there.
post #28 of 139 Old 03-08-2016, 04:25 AM Thread Starter
Carlos76's Avatar
Oil in TTX should be changed regulary, just let the technitian to change the shims to proper spec at the same time. Simple job and should not cost much extra.
CanyonCarver likes this.
Carlos76 is offline
post #29 of 139 Old 03-09-2016, 09:29 AM
Squid wannabe
rafa's Avatar
This is interesting. If the Gen 5 link is similar to the race links for the Gen 4 might be worth a while using stock gen 5 link on the gen 4 for racing.
Being that it is a "stock" link the bike technically would still be eligible to supersport/superstock rules.
"The ZX-10R is capable of being perfectly docile and tractable, but few men are capable of resisting its ever-present voice urging them to just twist it and see what happens."
rafa is offline
post #30 of 139 Old 03-09-2016, 09:51 AM
Vonstallin's Avatar
Images: 16
Ive never known links to be Illegal for super stock.
Then again, i havent read the rule books on them
