Gen 5: 2016 -> Gen5 rear suspention link info needed - Page 2 - Kawasaki ZX-10R.net
 23Likes
post #11 of 139 Old 01-21-2016, 08:20 PM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Originally Posted by Carlos76 View Post
KA364 according to www.ohlins.EU
If it turns out that KA364 uses from factory a spring 95...105, then it is a hint that gen5 link ratio is similar to aftermarket link. In this case I would wait selling your Ohlins (gen4) shock, if it is valved for aftermarket link and you weigth, then just install it on gen5.
If gen5 shock is longer, then just add clevis shim to balance. If it is shorter and gen4 Ohlins will be too long, then Ohlins must be opened and made shorter by adding washers below topout spiring.
good to know...now just need to find out if the stocker or TTX is the Superior shock.
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #12 of 139 Old 01-21-2016, 09:19 PM
mpp12's Avatar
ttx will be superior.... no doubts about it.
fireman69 likes this.
mpp12 is offline
post #13 of 139 Old 02-03-2016, 08:59 PM
Vonstallin's Avatar
Images: 16
Maurice,
The shock you have will fit and work, it will need to be re-valved and re-sprung at a cost of $350.00 including a full service.
The front fork is good, we made some changes and made it really good. Cost to be determined, approximate $500.00
A suspension link is not needed however it definitely makes it better.
Cheers
I got this from Thermosman so I will send in my gen 4 TTX to get fixed for this bike.
So summary is...
2016 stock race links are ok/decent: better than 2011 stock
2011 MSS 4.0 race Links on a 2016 zx10r Is better than stock 2016, but just marginal... I need to send in the 3.5 race link info now...
post #14 of 139 Old 02-03-2016, 10:05 PM
Vonstallin's Avatar
Images: 16
Here are the 3.5 and 4.0 measurements.
ID:	355778   Click image for larger version
Carlos76 likes this.
post #15 of 139 Old 02-05-2016, 12:26 PM
LDH
LDH's Avatar
Both the Gen 4 and Gen 5 Ohlins shocks are the same length out of the box at 309mm
The new KA364 has dropped down to a 90Nm spring as their stock spring at least according to the preliminary data I reviewed yesterday which is 4 full rates less than the 110Nm on the Gen4. With that much of a change to the start rate of the linear linkage I am reasonably sure there will be a big valving change to go along with it.
I'm not 100% certain because I have not seen the new valve spec yet on the KA364, but I am leaning towards the idea that those Ohlins shocks for the Gen 4 that have been custom valved to work with the DK Linear Link will likely work with the Gen5 as is.
I will update when I get the new spec sheet.
Vonstallin, CanyonCarver and moto4 like this.
LDH is offline
post #16 of 139 Old 02-05-2016, 03:19 PM
Vonstallin's Avatar
Images: 16
I was told something similar to what you are saying.
I was told that my Gen 4 will work, but will need Re-valving..
Also told that the measurement from the MSS race links from the Gen 4 are a tad better than the OEM links on the Gen 5.
Do you think the OEM set up on the Gen 5 would need the shock shimed some?
On the Gen 4 we were adding 6mm to 10mm with stock links and shock.
The Gen 4 MSS race links and about 3mm of shims raised the bike up and gave it great feel on the front.
The stock Gen 5 feel taller than the Gen 4, but still seems like it can use shimming.
post #17 of 139 Old 02-05-2016, 03:31 PM
LDH
LDH's Avatar
I am hesitant to speculate any further without knowing the valve specs. Until I get that new spec sheet in my hands anything I say is subject to change.
Vonstallin likes this.
LDH is offline
post #18 of 139 Old 02-05-2016, 05:41 PM
Vonstallin's Avatar
Images: 16
Gotcha.
post #19 of 139 Old 02-08-2016, 05:09 PM Thread Starter
Carlos76's Avatar
Thank you Vonstallin for posting MSS Gen4 link measurements, this is good info for community.
I agree with LDH that revalving Gen4 Ohlins shock (as shipped by Ohlins) is much needed and if you have already revalved for Kyle link, then you are probably close to optimum.
Kyle link valving for gen4 is much softer compared to stock Ohlins valving, reason is because it's link ratio is 2.15, where stock ratio is 2.4. Difference of 11-12%, logically go down with spring and down with valving.
Now if Ohlins did put 90Nm spring for Gen5 then I speculate that link ratio may be even arround 2.1 (cannot be much higher than that) and Kyle valving will not be soft.
The problem is we don't know exact Gen5 link ratio number yet and how linear it is.
Very intresting and looking forward to know gen5 Ohlins valve spec form LDH and how it compares to Kyle spec.
Carlos76 is offline
post #20 of 139 Old 02-08-2016, 09:16 PM
Vonstallin's Avatar
Images: 16
What are Kyle valving or Race links?
I only knew of MSS and Attack Kawasaki Race Links.
Attack Kawasaki Race links should be the exact same measurements as the MSS "4.0" race links. Suburban Rancher purchased all three
MSS 3.5
MSS 4.0
Attack Racing Race links (mss 4.0)
I talk to Adam at MSS and they did make a 3.0 link but I think it was not great so they only made the 3.5 and 4.0.
From what he was telling me the
3.5 are for tighter tracks like what are found in America, while
the 4.0 are more for tracks Moto GP and WSBK would run.
I guess to compare American Track...NJMP vs. COTA
I have no clue, lol just quoting.
