Gen4 to Gen5 Exhaust Compatiblity - Kawasaki ZX-10R.net
 5Likes
post #1 of 15 Old 06-16-2017, 08:08 PM Thread Starter
So I've had a chance to try to test-fit a Gen5 full stock exhaust (Cat-back) on a Gen4 and it didn't fit. It seems like the part that is different between bikes is the not so much the location where the manifold ends but rather the location of the bottom mounting point, which Cat bolts up to. That obviously doesn't really matter since nobody will be swapping stock exhausts between bikes but what is great is that aftermarket exhausts don't use that mounting point at all. This means that aftermarket exhausts should fit both bikes. This includes slip-ons and full systems. Has anyone tried it yet?
Lanister is offline
post #2 of 15 Old 06-16-2017, 08:57 PM
mpp12's Avatar
Have a gen5 stock headers on my gen 4.
Enviado desde mi LG-D855 mediante Tapatalk
mpp12 is offline
post #3 of 15 Old 06-16-2017, 09:46 PM Thread Starter
Why? Are they better?
And does that mean the rest of your exhaust is designed for gen4 and it mates up with gen5 headers just fine?
Lanister is offline
post #4 of 15 Old 06-16-2017, 11:00 PM
Snakes709's Avatar
I have a yoshimura alpha 3/4 system for the gen5 on my gen 4. Only thing that had to be done is remove the gasket donut out of the header side. As well as the mounting point under the rear set doesnt match up. But the passenger peg mount holds it nice and tight
Lanister likes this.
2015 ZX10R
2016 ZX14R SE
Snakes709 is offline
post #5 of 15 Old 06-17-2017, 10:19 AM
skidooboy's Avatar
there are a few threads already on this. you can switch, they will fit, with some slight modifications. Ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #6 of 15 Old 06-17-2017, 01:08 PM Thread Starter
So it seems like location of the foot peg mounting points has been also changed on a gen5 from gen4.
Lanister is offline
post #7 of 15 Old 06-17-2017, 01:26 PM
Snakes709's Avatar
Maybe not. I recall hearing that the gen4 header is longer then the gen5. Overall lengths are rhe same but with the longer gen 4 header and the longer muffler section would put the mounting point off. But if you swap the gen 5 header with the gen 5 muffler on the gen 4, it should line up.
2015 ZX10R
2016 ZX14R SE
post #8 of 15 Old 06-17-2017, 01:48 PM
skidooboy's Avatar
gen 5 header is a bit longer, changing the lower mount area a bit. Ski
post #9 of 15 Old 06-17-2017, 01:57 PM Thread Starter
That explains everything :)
Lanister is offline
post #10 of 15 Old 06-17-2017, 05:08 PM
mpp12's Avatar
yes the gen5 header is a bit longer also the 4-2 section (collector) is bigger...
mpp12 is offline
