Gen 5: 2016 -> Gen 5 tuning questions, mainly idle - Kawasaki ZX-10R.net
 4Likes
post #1 of 34 Old 04-11-2017, 05:34 PM Thread Starter
dalemac's Avatar
Good afternoon! I'm working on tuning my gen 5 and have some questions. I've searched, but now real thread on tuning this bike.
Archer has been a godsend thus far, but I feel bad emailing with questions constantly.
Bike is almost brand new (215 miles) with Woolich logbox, slip on, ais blocked off and stock O2 disconnected.
I can't get it to idle for the life of me. I used the easy EU from map share and started auto tuning. The bike has unreal power, but idles like shit.
I've added fuel, raised idle to 1400 and tried to just auto tune with idling.
Please help! And feel free to post any tuning secrets you may have on this bike. It could help a lot of us new to the Zx10 (my CBRs were easy but slow in comparison)
dalemac is offline
post #2 of 34 Old 04-11-2017, 06:10 PM
The Pace
scout's Avatar
if it doesn't stall at a stop than stop over thinking this bike.
scout is offline
post #3 of 34 Old 04-11-2017, 08:51 PM
chiffeee's Avatar
I put one of my bikes map on map share , and use 1600RPM at Idle ,you may need more timing for different exhausts. 2016 ZX10R map ,Autotuned
working on Austin Racing exhaust right now ,fuel map is a bit different but using the same timing map.
dalemac likes this.
chiffeee is offline
post #4 of 34 Old 04-12-2017, 08:50 AM Thread Starter
dalemac's Avatar
While I understand your point, I have to disagree. Having a brand new bike that you're ashamed of while idling at a stoplight or in the pits is not ok.
And I'm an engineer, I was trained to overthink everything....
dalemac is offline
post #5 of 34 Old 04-12-2017, 08:53 AM Thread Starter
dalemac's Avatar
1600? Wow, I wouldn't have thought to go that high. I was kinda uncomfortable with 1400. I'll pull your map and take a peek at it.
Right now I have auto tune trying for 13.2, thinking of adding a little more fuel.
dalemac is offline
post #6 of 34 Old 04-12-2017, 10:10 AM
Get an Ftecu flash from Nels
bbsteinnewyork is offline
post #7 of 34 Old 04-12-2017, 10:20 AM
chiffeee's Avatar
you don't have to do what i did,you ask a question and give you what I think is right for me, keep the RPM at 1000 add timing .
when you took the back pressure off the engine you have to correct it ,and fuel doesn't correct everything.
chiffeee is offline
post #8 of 34 Old 04-12-2017, 10:35 AM Thread Starter
dalemac's Avatar
I don't think you took my comment the way I intended. I was not attacking you or what you did to overcome the issue, just looking for info and experience.
Thanks for the help
dalemac is offline
post #9 of 34 Old 04-12-2017, 01:04 PM
chiffeee's Avatar
Here is the way i am doing it on another bike, the rider like you wants a low idle RPM so i set it to 1200RPM at idle.
on ignition map, I set his idle Ignition 1 degree higher, on .6 over 1000,1200 and 1400 RPM
IAP map, I change 24 through 18 over 1000 through 1400 RPM for richer fuel its between 400-500 ,you need to do this manually. then bring the Engine data up and look at A/F should be around 11-12 , you may need to add or deduct fuel for the exhaust you are running.
dalemac likes this.
chiffeee is offline
post #10 of 34 Old 04-12-2017, 01:21 PM Thread Starter
dalemac's Avatar
That's precisely the info I was looking for! Thank you!
dalemac is offline
