Gen 5: 2016 -> Gen 5 Stock QS & Tune - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By SkyDork
post #1 of 7 Old 05-01-2018, 12:03 AM Thread Starter
Call me crazy, but prior to installing new exhaust and tune (no changes to QS settings), my QS was unpredictable. My bike would sometimes lurch when using QS, low, mid, or high rpm (less at high RPM, more at mid, and I rarely QS at low - all under load). After the exhaust and tune, it is way better (still a little too slow for my liking - like just a tad, but on par for manual no clutch shift). Is this because of the tune (de-restricting, increased HP, etc?)
There were no changes to stock QS settings.
Anyone else experience this before and after tune?
GearsNStuff is offline
post #2 of 7 Old 05-01-2018, 01:03 AM
Victors's Avatar
Nope. Likely just in your head
2013 10R
2007 650R
2016 10R
Victors is offline
post #3 of 7 Old 05-01-2018, 08:26 AM
SkyDork's Avatar
The quickshifter is designed for full throttle track use. Using it a low RPMs is not what it's designed for. If used at part throttle openings that is not what it's designed for. If you're below 8,000 RPM, don't use the QS. If you're not near full throttle, don't use the QS. And I always recommend not using the QS at all for the 1-2 shift.
Boxtradamus likes this.
#WordCrimes
SkyDork is offline
post #4 of 7 Old 05-01-2018, 08:30 AM
You are 100% correct with everything in this post.
Boxtradamus is offline
post #5 of 7 Old 05-01-2018, 08:40 AM
SkyDork's Avatar
#WordCrimes
SkyDork is offline
post #6 of 7 Old 05-01-2018, 12:13 PM
ddipaola's Avatar
My QS is as smooth as butter, but particular. It will be a little jerky if I'm not above 6K RPMs or if I'm not accelerating. First gear ratio is very torquey so I tend not to clutchless upshift out of or downshift into it. I didn't own the bike when it was completely stock, picked it up modded and flashed, so I can't tell you if anything changed post-mods, but I wouldn't doubt a flash improves the "smoothness" as most flashes do.
When in doubt... send it!
ddipaola is offline
post #7 of 7 Old 05-02-2018, 08:58 PM Thread Starter
This is what I'm thinking. I know I said to call me crazy, lol, but seriously the bike would lurch, and I wasn't too happy to QS while moderately leaned in a wide sweeping turn. This is a stock restricted USA model (for you lucky Euro folks).
After flash tune the bike hasn't lurched at all, and I have stronger midrange. This might be in my head - but probably not based on dyno results with same mods.
