Gen 5 O2 sensor connector locations - Kawasaki ZX-10R.net
post #1 of 4 Old 02-17-2017, 08:15 AM Thread Starter
peterj59's Avatar
Exclamation Gen 5 O2 sensor connector locations
had my ecu flashed by Guhl motors, well i can't seem to find where the other end of the o2 sensor is to disconnect it, does anyone know where it is??
peterj59 is offline
post #2 of 4 Old 02-17-2017, 09:19 AM
turtle1000's Avatar
There was recent discussion of it being under tank. Can't say where exacty. Surprised they don't offer instructions. Many have done it already here so I'm sure they'll chime in.
More cowbell
turtle1000 is offline
post #3 of 4 Old 02-17-2017, 10:00 AM
2K16/10r's Avatar
I actually just did mine this past week. On the 2016 ZX10R, the O2 sensor plugs in under the tank. You have to get the tank propped up, on the RIGHT side of the bike (brake side) directly behind the air filter housing box you'll see a connector with four wires going into the plug with a sheathing/cover over the wiring. That plug is for the O2 sensor. Pull the wiring gently in either direction with one hand on the wiring AT the O2 sensor itself to put your mind at ease that it is the connector for the O2 sensor. If you look at the manuals posted on the forum I believe there is only one diagram that actually shows where the O2 sensor is located.
2K16/10r is offline
post #4 of 4 Old 02-17-2017, 10:15 AM Thread Starter
peterj59's Avatar
so i have to also remove the airbox too
peterj59 is offline
