Gen 4 to Gen 5 rear shock swaps - Kawasaki ZX-10R.net
post #1 of 7 Old 07-31-2017, 12:13 PM Thread Starter
A newbie here and I have said Hi in the introduction thread.
I have a Gen 5 10r and I would like to upgrade the rear shock, Ohlins,Bitubo etc.
I have been told that a Gen 4 shock will fit ini a Gen 5 as long as you use the Gen 4 linkage.
Has anyone done this or can confirm that this is the case?
Cheers
10rAlex is offline
post #2 of 7 Old 07-31-2017, 02:27 PM
Gen4 and Gen5 shocks are different lengths so it's not a good straight swap.
Lanister is offline
post #3 of 7 Old 08-02-2017, 09:40 AM
fireman69's Avatar
If you buy a aftermarket shock from a gen 4, it will fit a Gen 5. But like lanister stated, you will need to change the shock length to suit. All aftermarket shocks will have a length adjustment on them.
fireman69 is offline
post #4 of 7 Old 08-02-2017, 03:15 PM
Porschenut's Avatar
I'm currently playing with different components and am running my Gen4 swing arm with Gen4 shock and Gen5 links and Gen5 dogbone. It's only temporary until I can swap in my Gen5 shock.
All the Gen4/5 parts interchange though a Gen5 has a higher rear ride height (due to the revised links and dogbone) than a Gen4 out of the box.
If you simply swap in a Gen4 shock body then your rear ride height will increase because the Gen4 shock is longer.
Porschenut is offline
post #5 of 7 Old 09-26-2017, 01:04 PM
mpp12's Avatar
What if you change in a gen4, and put a gen5 shock, plates and dog bone????
mpp12 is offline
post #6 of 7 Old 09-26-2017, 04:02 PM
Porschenut's Avatar
I'm currently running a Gen 5 shock, plates and dogbone.
post #7 of 7 Old 09-26-2017, 09:28 PM
KJP
I have a Gen 4 Ohlins mint, condition in the for sale section. Has ride height adjustment or could be shimmed.
KJP is offline
