Gen 5: 2016 -> Gearing on Gen 5 street and Track - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 16 Old 11-06-2017, 09:45 AM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Originally Posted by mpp12 View Post
gen5 on the street my tune for customers is +1R, that is almost same as gen4 -1F.
track, gen5, I would start -1F, see how it feels, and start from there...
if you want the excel file I use I have one with gen4 and gen5 on the other sheet, so you can compare, just needs your tire circunference...
motoseteo@gmail.com
That would be cool, thanks.
I have my tire circumference also on my phone. I used that in the TC portion of the Woolich Flash (Pirelli Super Corsa SP 200/55)
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is offline
post #12 of 16 Old 11-07-2017, 02:45 PM
Niner1000RR's Avatar
No street here, but I range between 17/40 and 17/42 depending on the track.
Niner1000RR is offline
post #13 of 16 Old 12-04-2017, 07:35 PM
Track only here, I do 16-39 or 16-40. I prefer 16-39 so I can use first gear to rocket out of slow corners.
Keeping the stock front at 17 and doing 40-42 in rear like Niner1000RR is actually better for chain wear, but you will need to get longer chain to keep your wheelbase fairly long.
cca101 is offline
post #14 of 16 Old 12-04-2017, 10:10 PM
Ron Mears's Avatar
Originally Posted by CanyonCarver View Post
Gen5 Track = -2F/+0R
Are you having any clearance issues between the swingarm pivot and the chain? I test fit a 15 to the counter shaft and even with a 41 on the rear, which would raise the chain a little, there didn't seem to be enough room between the pivot and the chain at the swingarm angle I run. So I haven't gone any smaller than 16 front.
Ron Mears is offline
post #15 of 16 Old 12-08-2017, 08:20 AM
CanyonCarver's Avatar
No problems at all after 2 years of track duty (~7k miles or so), and 2 sets of gears/chain.
Ron Mears and Schooley like this.
CanyonCarver is offline
post #16 of 16 Old 12-20-2017, 04:03 AM
Siwa's Avatar
Equivalent to 17-43, but has improved drive on corner exit due to the reduced squat to stand range of the swing arm. Also slightly reduces wheelbase.
Have to be very precise with the throttle on exit though else you can end up robbing yourself of time due to the front lifting and the rear stepping out.
Also make sure the swing arm and chain have the correct measurements to ensure that under decel when the rear end squats, the chain goes in a straight line from the top of the front sprocket to the rear. When you downshift the chain ripples like a whip crack and if it has to move up or down to meet the front sprocket teeth then it can jump a tooth or completely jump the sprocket.
CanyonCarver likes this.
2016 - ZX-10R KRT Winter Edition
https://www.instagram.com/superbike.turtle/
Siwa is offline
