Gen 4: 2011-2015 gear shift lever - Kawasaki ZX-10R.net
 15Likes
post #1 of 81 Old 08-06-2016, 12:59 PM Thread Starter
mpp12's Avatar
gear shift lever
Does anyone know how the make the gear shift lever more precise, if you make contact with the lever you would notice that first it bends from the pivot then transfer the force...
I just want to make it tighter, so all the force applied is transferred..
thanks
mpp12 is offline
post #2 of 81 Old 08-06-2016, 04:27 PM
The Pace
scout's Avatar
Nothing wrong with oem's and I pound the crap outta it. up and down, four hours per day no clutch; nearly 100k miles. Math is done for you.
evilaugust likes this.
scout is offline
post #3 of 81 Old 08-06-2016, 10:02 PM Thread Starter
mpp12's Avatar
the question was not, is it durable...
I just want to be more precise, like aftermarket ones....
mpp12 is offline
post #4 of 81 Old 08-07-2016, 09:09 AM
dricked's Avatar
If you seek you shall find your answer ;)
dricked is offline
post #5 of 81 Old 08-07-2016, 10:41 AM
SpazOnaZX's Avatar
I had that problem on my concours... I replaced the larger shoulder/stepped pivot bolt with 4 or 5 very small ball bearings and a smaller bolt. The bearings were very cheap (I got a stack of 10 for about 6 bucks), and it took out all of the lateral slop. I haven't looked at the set up for the Gen 4/5, but if you take a quick picture of it apart I could tell you if it would work. :)
EDIT: This is a lot like what I did, but I changed a few things for my preference. IIRC, I used the same bearings on a Gen 2 10R to clean up that shifter as well.
SpazOnaZX is offline
post #6 of 81 Old 08-07-2016, 11:11 AM Thread Starter
mpp12's Avatar
Thanks
mpp12 is offline
post #7 of 81 Old 08-07-2016, 11:30 AM Thread Starter
mpp12's Avatar
I will disassemble one that I have as a spare to see how it can be done...
skidooboy likes this.
mpp12 is offline
post #8 of 81 Old 08-07-2016, 11:33 AM
skidooboy's Avatar
make sure you come back to tell us, what you find, and how you "fixed it". enquiring minds, want to know. :D Ski
May we all, get to have a chance to ride the fast one, walk away wiser when we crash one, keep hopin that the best one is the last one.
skidooboy is offline
post #9 of 81 Old 08-07-2016, 04:47 PM
SpazOnaZX's Avatar
For sure. I have a few of those bearings still laying around too.... if the measurements are the same I'll throw them in the mail to you.... just post up your dimensions when you get the chance.
post #10 of 81 Old 08-09-2016, 08:51 PM Thread Starter
mpp12's Avatar
This could be done 2 ways one its fitting a tighter brass insert so its way less play with the ss bolt Another to get a ball bearing insert it in the bolt of course you have to machine the bolt and press the lever
Enviado desde mi iPhone utilizando Tapatalk
mpp12 is offline
