Gen 5: 2016 -> Are fuel maps usually linked to a power mode ? - Kawasaki ZX-10R.net
 2Likes
  • 2 Post By chiffeee
post #1 of 3 Old 05-22-2018, 12:57 PM Thread Starter
lun471k's Avatar
Might look like a stupid question but I don't really know much about ECU flashing.
If I go in Medium power mode, is it the same map as the Full power mode once flashed and tuned ? Do people usually overwrite all three power modes ?
My latest reflash & retune totally screwed up my bike, it's far from perfect right now and I'm wondering if putting it in Medium could fix the problem until I get a proper tune.
I'll test it by myself tonight, but since I'm at work I was wondering if anyone knew about that. Thanks guys !
lun471k is offline
post #2 of 3 Old 05-22-2018, 01:04 PM
chiffeee's Avatar
fuel and ignition map all are same on stock ECU , the power gets change from full to rain with ETV map
SkyDork and lun471k like this.
chiffeee is offline
post #3 of 3 Old 05-22-2018, 03:16 PM
SkyDork's Avatar
The ignition maps are not gear specific. The fuel maps can be trimmed per gear and per cylinder. As chiffeee said, the base map is the same for fueling for all power modes, but different between individual cylinders. That is the difference from the G4 to G5.
The older model didn't have ride-by-wire so the power modes were controlled via fueling/ignition differences. With the ETV mapping now, all of that is controlled via the ETV alone. You can still save off different power maps for fueling differences though if you want.
#WordCrimes
SkyDork is offline
