Gen 5: 2016 -> Forks too stiff? What about rear. - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 15 Old 09-19-2017, 08:35 AM
Carlos76's Avatar
Originally Posted by 10Arghh View Post
Can you ask them what they felt was wrong with the stock front units.
By the way, you quote the x seconds from lap record thing quite a bit, but I don't think that is that useful considering the wide variety of track configurations and riding styles that exist.
Case in point...James Ellison set the fastest ever two wheeled lap around Brands Hatch Indy circuit this year in British Superbikes, doing a 45.097s - crash.net.
Yet even rookies on stock 1000s are doing high 50s around there.
Yes, "x seconds off lap record" is bad measurement. Best we compare to Superstock1000 bikes where qualifying normative is usually 107% to 110% of the winner of qualifying time. 110% makes only +5s in Brands Hatch, but in Brno +12s!
Three years back my pace was at 112% and I could not make any difference between running Gen4 stock forks and Ktech cart. At 110% started a little to feel what front end is doing. Now my pace is 107% and I'm just starting to understand what the term "front end feel" maybe really means, while my corner entry and trail braking still sucks.
I think gen5 stock forks are easily sufficent unil some 109% pace. Boys I meantioned (running Andreani) are at 105%, I know their tuner and he said simply that piston kit makes it "race oriented fork" (whatever it means), but more importantly he makes forks to use all avaliable stroke because with stock settings gen5 fork rides too high and does not "point the nose well" mid corner. I quess it likes to drive little wide because of that, I'm not an expert.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #12 of 15 Old 09-19-2017, 09:17 AM Thread Starter
Thanks...Yes I always thought a percentage was a better way to represent that.
My style has been to run into a corner and try to carry a lot of speed through it. This worked fine for me just doing track days for 10 years especially with Bridgestone R10s that promote this style of riding.
However, I learned within the last 3 years from Simon Crafar that to use the full potential of a superbike, you need to maximise drive out of corners using a more square line out of turns. And I have been trying to ride like this ever since, but found the limit on my GSXR 1000 K5 a few years ago, when I fired myself into the air using too much 'drive', funnily enough trying to catch a guy on a gen 4 ZX10R with full TC :D
Whilst I had my G4 I found it was a harder bike to steer, but never got to try it on track before it was stolen.
The G5 will be track only and I'm on a budget, but I hear there is more to get the bike working right with the stock equipment than previous models.
I still have my Bitubo shock which I likely will have to change the valving in to work with the G5, then the next step will be Bitubo gas cartridge kit.
Got to start saving ££££
Btw, how are you liking your adjustable yokes (triple clamps)?
10Arghh is offline
post #13 of 15 Old 09-19-2017, 10:38 AM
Carlos76's Avatar
I have adjustable triples at 30mm offset (stock is 26mm), I like them because steering requires less force and no ill sideeffects, but there is no laptime advantage from them. Just did build almost same spec gen4 for my brother and riding back to back with stock triples I can say that it something that "102%" racer could need to shave 0.1s per lap.
Remember watching Crafar video where he said: stay leaned over for 1s longer than usual then you can pick bike up quickly and have much earlier drive. Strong pull at inner handlebar, bike stands up quick, grip goes progressivley up, hard throttle possible. Many rookie races have proper mid corner speed, but stay leaned over "forever" and roll on at constant lean angle (highside danger).
P:S Try spending more money on trackdays than building the bike.
Carlos76 is offline
post #14 of 15 Old 09-20-2017, 04:22 PM Thread Starter
You made me think now.
Maybe I don't buy a Gen 5 and just use the money on a race season with my race prepped GSXR1000K5 (full Ohlins, gas flowed head, cams and quick shifter).
Would have to buy aftermarket TC package, but still thats £600 rather than £10000.
10Arghh is offline
post #15 of 15 Old 09-21-2017, 07:08 AM
Carlos76's Avatar
You keep GSXR as backup bike in case you have crash or engine failure.
A local trackday costs around 250 euros when using second hand tires.
If I race or travel then new tires and it costs arround 600-1000 euros per day.
Spare parts, maintenance gear and many other items cost 3k to 5k per season.
In order to "race" you need to do at least 20 days per season resulting roughly 15k per season plus new bike every 4 years.
Private budget rookie superstock case.
Carlos76 is offline
