Gen 5: 2016 -> Flapper Valve Removal in Ram Air - Kawasaki ZX-10R.net
 22Likes
post #1 of 78 Old 04-21-2016, 02:02 AM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Cool Flapper Valve Removal in Ram Air
So, I see the USA model finally have the Euro spect Flapper Valve inside the ram air tubes like Euro 2011-2015 Gen 4 Kaws.
I want to remove it since I can not figure out any benifits of having a flapper close up as you go faster.
Can anyone think of a reason to leave it?
Once my exhaust comes in, I am installing block off plates and want to remove the flapper.
My usa model gen 4 never had a problem with no Flapper.
I saw a Gen 4 thread where they said leave the Valve connected to keep from getting an error code.
I wonder if the woolich flasher would get rid of that error code?
Anyone remove theres off the Gen 5?
or have plans to remove it?
Any benifit to keeping it on?
Removal Flapper valve in Ram air
WERA Novice 325 | CCS Novice 326 | The Nightmare of Summit Point
2016 ZX10R ABS (Street) | 2011 ZX10RR(Race) | 2011 R6 (Street & Track) | 2009 WR250F
GunnRunnaz.com|GR on FaceBook | www.2666ad.com|
Vonstallin is online now
post #2 of 78 Old 04-21-2016, 06:56 AM
Mine is gone from my gen5. Flash tune removed the engine codes so you don't get any errors. I can't think of one reason to leave it in. Get rid of it and don't think any more about it.
Vonstallin likes this.
gsxrvette is offline
post #3 of 78 Old 04-21-2016, 07:38 AM
Mach.81's Avatar
Air pump and flapper are coming out!
Haven't decided yet on plan of action but both are being removed.
Mach.81 is offline
post #4 of 78 Old 04-21-2016, 08:04 AM
CanyonCarver's Avatar
It's going to disappear when the kit ecu gets installed. Expect that it's mostly a noise-abatement feature.
CanyonCarver is offline
post #5 of 78 Old 04-21-2016, 10:01 AM Thread Starter
Vonstallin's Avatar
Images: 16
Good to know someone already removed it.
I wonder if the Woolich unit will get rid of the engine code. I would expect it would.
I can deal with noise if that is the only purpose of the flapper.
I had a 08 CBR 1000RR that had two flappers on the ram air. I removed them and no issues and the bike ran faster...well felt like it did.
post #6 of 78 Old 04-21-2016, 10:28 AM
turtle1000's Avatar
one more thing to unleash gen 5 huh. That sucks. Tearing into the front must be a pita. Good luck
More cowbell
turtle1000 is offline
post #7 of 78 Old 04-21-2016, 01:29 PM
Wasn't bad at all. Tear the entire nose off and straight forward from there
post #8 of 78 Old 04-21-2016, 02:34 PM
You can order the plug from the 2015 to cover the whole when you remove the flapper.
ajn507 is offline
post #9 of 78 Old 04-21-2016, 03:55 PM Thread Starter
Vonstallin's Avatar
Images: 16
any info where or part number?
post #10 of 78 Old 04-21-2016, 04:51 PM
92066-0717 its like $6 from dealer
ajn507 is offline
