Gen 2: 2006-2007 Engine Tapping what could it be? - Page 2 - Kawasaki ZX-10R.net
 3Likes
post #11 of 16 Old 05-13-2018, 02:18 AM Thread Starter
Yeah I agree, something is hitting something but can't imagine what else it could be. If it were a rod knock (or rod tap) then the rod bearings would have looked abnormal when I had that apart. I'm sure it has to be the valve tapping the head or the valve hitting the top of the piston (which would normally bend it or shatter it). I will keep you updated I am going to break it apart again this week to see if I can see anything that I may have missed.
parson.phillip is offline
post #12 of 16 Old 05-13-2018, 05:09 AM
michael4012's Avatar
I think if you don't find anything on your gonna split the cases measure out little & big ends check for broken rings and damaged skirts, was there any unusual marks on the cylinders? Mate i hope someone comes along with a fresh idea.
[SIGPIC][/SIGPIC]192MPH stock engined 2008
michael4012 is offline
post #13 of 16 Old 05-13-2018, 07:52 AM
I always carry one of these on my service truck. Lots of different sources sell them.....
https://www.aliexpress.com/item/WINM...380660717.html
They help when you have a noise ,like yours, where you are not 100% sure of where its coming from.
rcannon is offline
post #14 of 16 Old 05-13-2018, 09:14 AM
ZX10's Avatar
Originally Posted by parson.phillip View Post
Alright everyone knows about the Kawi Tick right. I have a Tapping sound coming from the engine. Sounds like it's coming directly from the exhaust ports. I have removed the head and checked for any play in the pistons (for possible slipped bearing) no play in all 4 pistons still tapping. I have replaced the cam chain tensioner still tapping. I did a valve clearance check all are well within spec (I checked the manual for the proper clearance) still tapping. I thought maybe it could be the valves so I replaced piston 2 and 3's exhaust valves and its still tapping haha. Any thoughts ?
What I have done to it:
1) Replaced cam chain
2) Replaced cam chain tensioner
3) Checked for rod knock
4) Checked valve clearance
5) Replaced piston 2 and 3 exhaust valves
Any help would greatly be appreciated.
Do you have a quick way to check the crankshaft straightness and connecting rod straightness? If it is not in the tolerances then may be check for straightness.
michael4012 likes this.
ZX10 is offline
post #15 of 16 Old 05-13-2018, 01:00 PM
chiffeee's Avatar
sticky valve, the sound is more on the number 1 cylinder. replace valve guides.
chiffeee is offline
post #16 of 16 Old 05-13-2018, 08:06 PM Thread Starter
I will try that tonight and see if it helps it.
