Easy shock removal? - Kawasaki ZX-10R.net
 6Likes
post #1 of 13 Old 05-07-2018, 02:53 PM Thread Starter
Easy shock removal?
Does anyone know if you can swap the shock through the big hole in the swingarm?
I can get the top bolt ok.
I want to be able to swap to a softer setup for the road
ukzx10r is offline
post #2 of 13 Old 05-07-2018, 09:27 PM
The Pace
scout's Avatar
Do you have oem shock in the bike? If so, don't change it. Shock is set up for suspension not comfort although I ride a lot and never have comfort problem.
You're always busy, but in an interesting way, not the typical vendor hooked way.
scout is offline
post #3 of 13 Old 05-07-2018, 11:27 PM
badexample's Avatar
You can use a jack between the rear tire and subframe or a basketball.. inflate and deflate..
The best is a pair of Jack stands from Pit Bull that support the bike with the pegs.
ddipaola likes this.
“Ride like you are invisible.”
badexample is offline
post #4 of 13 Old 05-07-2018, 11:29 PM
badexample's Avatar
Scout , I would never take any mechanical advice from you !ahahahah
Getting your suspension resprung to your weight with proper sag is essential to happy brappppp!
mpp12 likes this.
post #5 of 13 Old 05-07-2018, 11:38 PM
Newf's Avatar
Easy shock removal?
Gen5? Depending on shock length if you take off the rear wheel the swingarm will drop enough to squeeze the shock out between subframe/swingarm.
And a modified top bracket helps also.
badexample and michael4012 like this.
Newf is offline
post #6 of 13 Old 05-08-2018, 03:59 AM Thread Starter
i have a mupo shock with a 115 spring and only 10mm seat foam.
I hit a bump yesterday and i swear im an inch shorter now lol.
Bike exits the corner superbly now but on the road im not too fussed about awsome corner exit speed. Id rather save my spine a bit.
Ive changed shock loads but never tried to wothout removing the tank.
Ive got titanium top mount with thread in it so its ok to take bolt in and out but i need to be able to get the shock out of the swing arm somehow.
Maybe i will give it a go at the weekend. Just wondered if anyone has tried it already to save me the agro trying?
ukzx10r is offline
post #7 of 13 Old 05-08-2018, 07:29 AM
ddipaola's Avatar
I've seen homemade tools done before (like on my FZ09 for instance) for an easy shock removal. +1 to that if you want to swap shocks back and forth for an independent street/track set-up.
Also I have to agree with Scout though in a sense. If comfort is solely your goal, and you've got like 3" chicken strips, you can do whatever you want. If you plan to ride aggressively at ANY point then I would stick with OEM. The Frt and Rr suspension are designed to work together to output a certain ride frequency (in other words they work together to settle the bike when the suspension is acting). For a race bike, you want a ride frequency with VERY short wavelengths (aka a stiff suspension). Certain disruption to the ride frequency whether that be via poor compression damping, rebound, pre-load, etc. can result in a pogo effect. There's a reason suspension tuning is an actual service some dealers provide and it's not cheap because it's tedious. The last thing you want is to enter a corner hot and all the sudden the ass-end of the bike starts pogo-ing and dancing on you and then you wake up to find out you're the victim of a RNickeyMouse YouTube video lmao.
When in doubt... send it!
ddipaola is offline
post #8 of 13 Old 05-08-2018, 07:29 PM
The Pace
scout's Avatar
nothing is more comical than you talking suspension!
scout is offline
post #9 of 13 Old 05-08-2018, 07:34 PM
The Pace
scout's Avatar
yes, but let me clarify. oem suspension is set up for flick and throttle. If soft shock, pegs will strike asphalt as MORE throttle is needed to lift the bike into engineering turning specs; so soft suspension is a no no with any super bike. The throttle, even just cracked, in the turn, keeps the oem suspension working; the REAR turns the bike, not the front; the front flick sets up the turn, not the rear; and some weight into the turn finishes the formula.
scout is offline
post #10 of 13 Old 05-08-2018, 11:42 PM Thread Starter
Every decent racer has a selection of springs to adjust the amount of movement for different tracks.
Im not a racer but the bumpy uk roads are nothing like the smooth uk tracks.
Its all about compramise with suspension.
I just need to try find easier way as im fed up with removing my tank and seat unit.
I will try soon and post results.
ukzx10r is offline
