Gen 5: 2016 -> The Dyno Results Are In - Page 3 - Kawasaki ZX-10R.net
 7Likes
post #21 of 40 Old 05-14-2018, 01:26 PM Thread Starter
ddipaola's Avatar
Originally Posted by GearsNStuff View Post
Yes. You can see right through this filter. Their filtration claim seems a little (lot) far fetched, and I question that it is "waterproof". After purchasing, I lean to the side of I shoulda got the standard p08.
But hey, what exhaust do you have? Block off plates? Do you still have your stock O2 sensor installed?
1: Graves low mount exhaust. I might switch over to the high mount though because they told me it can add like 5HP to the midrange.
2: The O2 sensor is still in, but it's disabled. I will be replacing the stock sensor with an FT ECU active-tune unit though after this second round of tuning.
3: No block off plates. Not a fan personally.
I will let you know how I like the MWR filter. They're a little pricey over something like a P08, or BMC, but they're cheaper than the F1's/P16s. They're a sponge-type filter which I've never ran before so we'll see. Maintenance will obviously be more extensive than just blowing air at it haha.
When in doubt... send it!
ddipaola is online now
post #22 of 40 Old 05-14-2018, 04:34 PM
I have the low mount, I believe low mount shorty pipes boost midrange, and the longer high mounts boost top end.
Also, pretty sure your 02 is NOT disabled. FTECU software simply disables the error code from being thrown when the sensor is disconnected from the bike.
Furthermore, you have to disable AIS if you want to get accurate readings on the dyno or for that matter, active tune
I was looking forward to seeing your dyno since we are pretty close in setup, but now that I know you still have 02, and AIS, still interested, but not so much anymore, lol...
2K16/10r likes this.
GearsNStuff is offline
post #23 of 40 Old 05-14-2018, 04:58 PM
post #24 of 40 Old 05-14-2018, 07:32 PM
Victors's Avatar
His 02 doesnt effect wit 100%
2013 10R
2007 650R
2016 10R
Victors is offline
post #25 of 40 Old 05-14-2018, 09:28 PM
Wouldn't his stock 02 sensor mess up the graves map he has installed?
For that matter, how does he have his stock 02 sensor installed? His pipe only has a wideband bunge... So maybe he doesn't have it installed, lol???
Anyways, I am still looking forward to his dyno.
post #26 of 40 Old 05-15-2018, 07:14 AM Thread Starter
ddipaola's Avatar
Ah gotcha. Would disabling the AIS via the FT software fix that issue or is will it work best combo'd with actual plates?
And I'll keep you guys updated with the results for sure. Hoping to have something by Friday/Saturday once some parts come in.
I've got some prototype velocity stacks in the works too so we'll see if that gets me an anticipated 1-2HP gain or if they'll be a bunch of hoopla like most.
post #27 of 40 Old 05-15-2018, 07:36 AM Thread Starter
ddipaola's Avatar
There's an O2 sensor hooked up to the exhaust haha I have no idea if it's doing anything but it's in there, I did check .
I'm the second owner so the exhaust and FT unit was all previously installed. I learn new things everyday I guess lol.
post #28 of 40 Old 05-15-2018, 08:47 AM
neonmarine's Avatar
I've got some prototype velocity stacks coming in too so we'll see if that gets me an anticipated 1-2HP gain or if they'll be a bunch of hoopla like most.
What stacks?
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
neonmarine is offline
post #29 of 40 Old 05-15-2018, 08:57 AM
michael4012's Avatar
Yeah what stacks 🤨
[SIGPIC][/SIGPIC]192MPH stock engined 2008
michael4012 is offline
post #30 of 40 Old 05-15-2018, 10:56 AM
You can't disable AIS in software, it's a mechanical process. You either have to install block off plates, and/or disconnect the hose from the left underside of the airbox, and install a little rubber cap. Did you watch Brock's video in one of my previous posts above?
as far as your 02, I just checked my bike, and well I'm stupid (should be no suprise, lol). The stock 02 bunge is located on the header pipe, so you can leave it alone, and on the graves pipe there is a wideband bunge where I have my wide band 02 installed.
as far as whether or not to install block off plates, not installing will make the pipe backfire a lot on decel. Some say this is fine, others say it can harm your valves and stuff due to excessive heat. I chose to just go ahead and do the plates because A) The pipe already draws enough unwanted attention without all the backfiring and B) I'd rather be safer than sorry, as I would like to keep the bike for a good while, and I tend to romp on it a lot C) I figured that by not disabling AIS, my auto tune would not be accurate (same as when on a dyno with an aftermarket exhaust)
Oh and like everyone else ... what stacks?
