Duct Installation - Kawasaki ZX-10R.net
 2Likes
post #1 of 15 Old 11-29-2017, 01:53 PM Thread Starter
iroman's Avatar
Duct Installation
So I conducted a search but was not able to find anything on this topic. Does anyone have an easy way to reinstall the ducts? Items 14073 b & C
iroman is offline
post #2 of 15 Old 11-29-2017, 02:18 PM
NinjaLife's Avatar
I don't know of an easier way other than fighting with them and swearing at those damn things.
In all seriousness, maybe a little heat will soften them and make them easier to work with, other than that I twist and push those fuckers in there and somehow make it work every time lol.
NinjaLife is offline
post #3 of 15 Old 11-29-2017, 02:32 PM
ZX10's Avatar
Wiggle wiggle??? hair dryer to soften up???
Install in frame first line up the bottom creases first and the sides and top fall into place when you wiggle it. Use your hand into the duct to push and grab the edge with thumb to pull. Push pull wiggle and it will fall into place again line up bottom first and work your way in a line up the sides and top. Once they are lined up put the airbox in no bolts yet and same thing line up the bottom first in the air box and work your way up the sides and top same way and can be persuaded into place with wiggling push pull and yea I haven't been successful without cursing and swearing ever.
ZX10 is offline
post #4 of 15 Old 11-29-2017, 02:40 PM Thread Starter
iroman's Avatar
Thanks guys, will try your suggestions but so far the swearing and cursing hasn't worked out; if it had, they'd be in perfectly... :)
iroman is offline
post #5 of 15 Old 11-29-2017, 02:48 PM
Bottoms-Up's Avatar
Silicon grease wiped around the edges.
Or.... Dielectric grease, petroleum jelly, etc.
I also use Dry Silicon spray on fairing tabs etc.
Bottoms-Up is offline
post #6 of 15 Old 11-29-2017, 03:05 PM
practice... lots of it.
Also i cut off the bits that go into the frame, don't really know if that improved air volume, but it made things a bit louder.
JayBoCC2 is offline
post #7 of 15 Old 11-29-2017, 03:16 PM
Capncalyx's Avatar
Ballsack. Need more ballsack. And seriously, if this is tough, you might not wanna take the bike apart any further lol.
Edit - just so im slightly supportive - i use a trick for stuff like this, usually made out of rubber, like my grips for example. I keep a bottle of rubbing alcohol around for cleaning and things like this. Drip some inside the grips and they slide right on and ive never had trouble with em not sticking. It evaporates in seconds when its all over. Same with getting grips off as long as no glue is used. Cram some inside the grip and start twisting - off in seconds.
evilaugust likes this.
Live Til You Die - QOTSA
We will all die but only a select few of us will ever truly live.
Last edited by Capncalyx; 11-29-2017 at 03:56 PM. Reason: try to be more supportive and less douchy
Capncalyx is offline
post #8 of 15 Old 11-29-2017, 03:32 PM
NinjaLife's Avatar
I thought about this route in the past but didn't know how well the rubber would hold up to the grease, I doubt the grease has any ill effects on the rubber but I didn't wanna take that chance.
I'm assuming you've tried the silicon/dielectric/petroleum? No issues with it like eating up the rubber or anything?
post #9 of 15 Old 11-29-2017, 04:02 PM
Capncalyx's Avatar
Its okay, as long as you use Elbow Grease!
post #10 of 15 Old 11-29-2017, 04:37 PM
Bottoms-Up's Avatar
Yes, no issues.
Been using all the above for many years on rubber parts, o-rings, etc.
