Gen 4: 2011-2015 Dropping Power/Cylinder Issue with PC V - Page 5 - Kawasaki ZX-10R.net
post #41 of 67 Old 10-13-2014, 08:39 PM
tukn20s's Avatar
Originally Posted by Bry View Post
Did you have the squealing too?
Damn bike kept running like dog crap. I updated the firmware and still had no change. I ended up removing the PC5 to try it without it for the second time. It did have the "stock/zero map" uploaded so I assumed the PC wasn't doing anything except powering on. After removing it, the bike has been running like a beast for the past few weeks. I haven't had time to get a hold of Dynojet about the unit, but will be doing so this week.
No squealing.
2012 ZX10R
Zero Gravity Corsa Windscreen
SATO Racing:
Frame Sliders,Bar Ends,Axle Sliders,
Swing Arm Spools,Racing Hooks,
Helmet Lock
Austin Racing GP2R
GUHL Flash
ASV Levers
R&G Radiator & Header Guard
Michelin Pilot Road 4's, Front/Rear
Targa FE w/ Rizoma turn signals
Spiegler Rennsport Brake Lines, Front/Rear
R&G Carbon Fiber Tank & Tail Sliders
Race Tech Tank & Knee Pads
Light Tech Chain Adjusters
tukn20s is offline
post #42 of 67 Old 10-20-2014, 10:43 PM
tukn20s's Avatar
Just got a package back from dynojet. They replaced my old pcv.
will be installing this wknd
2012 ZX10R
SATO Racing:
Helmet Lock
Austin Racing GP2R
GUHL Flash
ASV Levers
tukn20s is offline
post #43 of 67 Old 01-21-2015, 02:13 PM
Sent an email on this subject to Dynojet Technical Dept today and got this reply.
"The problem highlighted in this thread is a Firmware problem which came to light a few years back, the firmware update to the latest version (1.0.10.6) fixed this. I have not heard of this problem or seen it for a long time."
BladeRR8 is offline
post #44 of 67 Old 01-21-2015, 03:18 PM Thread Starter
Yeah the issue should've been fixed for good. This thread is just up at the top of the forums in case someone gets an old PCV with old firmware on it. Just to help mitigate additional topics on the subject since it has been fixed by Dynojet
ZX10RArcher is offline
post #45 of 67 Old 01-21-2015, 03:58 PM
Cheers for the info, sorry to be out of date glad to hear the issue is fixed
BladeRR8 is offline
post #46 of 67 Old 02-13-2015, 06:16 AM
veeru83's Avatar
Had this issue too. Tuner told me he updated it to V1.10.8.6.
My question is ... I can't even find this version on the official Power Commander website. Was he bluffing or do official tuners receive different firmware versions from those posted on the website?
Bike is running fine (so far). I live about 100 miles from the nearest tuner, so just wanted to make sure.
Also, if I have to update the firmware in the future, do I need to re-tune it, i.e. will my map disappear?
Thanks.
veeru83 is offline
post #47 of 67 Old 02-13-2015, 06:39 AM Thread Starter
Thanks.
I looked and couldn't find any reference to that version anywhere in my usual places.
So I can't speak if he is telling the truth or not. One way to find out would be to plug into your Power Commander with software and mini USB cable. That will tell you exactly what FW version is on there.
If you update the firmware, that will not change your map values.
post #48 of 67 Old 02-13-2015, 08:05 PM
tukn20s's Avatar
I called dynojet and explained what was going on..
i sent it in shipping paid by dynojet..
got a new one..
2012 ZX10R
SATO Racing:
Helmet Lock
Austin Racing GP2R
GUHL Flash
ASV Levers
tukn20s is offline
post #49 of 67 Old 02-14-2015, 08:34 AM
veeru83's Avatar
Hi Archer,
I managed to obtain the firmware from the local tuner. I've created a link for it which you can download:
https://www.dropbox.com/s/dypggl42rm...mware.zip?dl=0
Would you mind checking for me whether this is indeed firmware 1.10.8.6 as mentioned.
I'm getting paranoid riding the bike without being entirely confident whether it is dropping a cylinder. With the Racefit exhaust it's really hard to tell the difference as it's so god damn loud. Are there any long term effects on the engine if I keep running with 3 cylinders?
Thanks.
veeru83 is offline
post #50 of 67 Old 02-14-2015, 09:25 AM Thread Starter
I don't have a Power Commander any longer so I can't check the version. It also doesn't let you select the "Update Firmware" option without having a Power Commander hooked up and connected through the software. So unfortunately I can't.
It's not hard to do though, so if you have a laptop and a USB cable (mini USB), you can do it within a few minutes.
* Download the Dynojet software to your laptop: http://www.powercommander.com/downlo...5_v1.0.6.4.zip
* Install the software
* Connect the USB cable to your laptop
* Connect the other end of the USB cable to your Power Commander
* Give it the needed time to install the drivers for the Power Commander
* Open up the Power Commander software
* Look at the bottom status bar and make sure it says the Power Commander is connected
* Inside the Power Commander software click "Power Commander Tools" --> Update firmware.
* This will open up a new window and will show you the version currently loaded.
