Gen 4: 2011-2015 Dropping Power/Cylinder Issue with PC V - Page 3 - Kawasaki ZX-10R.net
post #21 of 67 Old 02-18-2014, 10:21 AM
Originally Posted by Aksonn View Post
I installed Guhl ECU flash and PC5 last week. I got first symptoms second day, no power, engine was "burping". Switched ignition off and back on. No issues for a week. Today at the morning, no power, engine sounded bad, "burping". During lunch break same thing, first worked well, then two times in a row one cylinder out and "burping".
Started to google.
FW was 1.8.5, now I updated FW to 1.9.2. I hope this will end this story. Will update.
It was working well one month after FW update. Even did one fast pace track day with it. No problems.
Having big issues now. I washed my bike this weekend and after that it has not run well. Immediately after wash I got Code 11 (Throttle sensor). I warmed up the engine and the Code did not appear again. Next day, same thing when I started the motor, Code 11. After 5min idling Code was gone.
After these two days I have not seen any Codes. Still my bike is not running well. This morning on my way to work, constant cut-offs, not just "burping" losing one cylinder, but I loose all power. Could drive like 40mph max. When gear is in neutral it revs fine.
Any ideas? I can try to downgrade to 1.6.10 today. I can open everything and check connections. Could water in the TPS connector cause this? Could loose gear position sensor/connection to PC5 (that one you need to splice) cause this?
Aksonn is offline
post #22 of 67 Old 02-18-2014, 02:55 PM
Edit. downgraded to 1.6.10, did not help. Still the same. Need to dig into the wiring tonight.
Aksonn is offline
post #23 of 67 Old 03-20-2014, 02:49 AM
Uncle Arthur's Avatar
Power commander firmware
I had this problem a couple of years ago and removed the PCV. I have booked my bike in with a really good local tuner and he is going to install it and Dynotune it. The latest firmware is. V1.10.6. Has anyone tried it. It was last updated on 1/6/2013 so I hope it is good. Thanks
Uncle Arthur is offline
post #24 of 67 Old 03-23-2014, 07:38 PM
Stomper1K's Avatar
I'm currently using the latest firmware from powercommander 700 miles later and still no problems *knock on wood * going in next Thursday for a custom tune currently running a graves slip on with bmc race filter and block offs with a generic tune loaded
Stomper1K is offline
post #25 of 67 Old 03-24-2014, 01:16 AM
Thanks stomper. Fingers crossed
post #26 of 67 Old 03-30-2014, 05:19 PM
Stomper1K's Avatar
Dropped bike off for custom dyno......Delivered to shop with damn near 900 miles on it after a few weeks of putting on heavy miles with latest firmware no issues (knock on wood) Will have dyno done on Thursday and will take some long rides after that, Will post in here again after a few thousand to confirm no issue.
post #27 of 67 Old 04-02-2014, 07:22 PM
Dropped my bike off with the guru this morning. It was running great anyway but if anyone can improve it it is Russel:)
post #28 of 67 Old 04-07-2014, 09:14 PM
Stomper1K's Avatar
Well for the sake of anyone wanting to know if the latest version firmware is still confirmed to work I feel pretty confident to say it does. Over 1,000 miles on my bike and she's good. Dyno was done last week put on about 200 since then and still good.
post #29 of 67 Old 04-12-2014, 06:41 AM
I did a track day today on the latest firmware. The bike ran perfectly.
post #30 of 67 Old 04-26-2014, 12:07 PM
Yup, over 2'500 miles with the new firmware and no issues whatsoever.
ArmyApe is offline
