Gen 4: 2011-2015 dashboard lights flashing - Kawasaki
post #1 of 5 Old 02-25-2018, 04:49 AM Thread Starter
I have a 2014 zx10R and I have a problem with the dashboard lights flashing and display also flashing. i noticed this occurring more in humid or hot weather. When bike is on the move the speedo readout jumps around as well. Has anyone else had this problem and does anyone know how to fix it please?
damo137 is offline
post #2 of 5 Old 02-25-2018, 12:30 PM
SkyDork's Avatar
Yup, you have a wiring/connector issue that's causing the serial CANbus communication link to fault. It's either that, or the whole cluster is faulty (not the most likely reason though). Pull the front cowling off, disconnect the cluster at the back, and check the connector. Same goes with the interconnect wiring between that and the ECU.
SkyDork is offline
post #3 of 5 Old 02-25-2018, 06:28 PM
The Pace
scout's Avatar
Sounds familiar. Did you change out front tire recently. I'm thinking front TC on wrong side. Check for the ring on left side.
scout is offline
post #4 of 5 Old 02-26-2018, 03:21 AM Thread Starter
Thanks for the replies! It's definitely not the Tc ring on wheel. I will take front cowl off at check the connections there and the ecu on the weekend. Cheers!! Damo
damo137 is offline
post #5 of 5 Old 02-26-2018, 07:53 PM
Porschenut's Avatar
I've had that problem for awhile now. I tried checking and cleaning connections (electronics cleaner spray) on the back of the cluster as well as at the ECU 3x now with no change. All the connections were spotless despite the fact that I've ridden my bike through 3 Canadian winters and salty road conditions.
I've also checked the primary ground connection underneath the fuel tank 2x but that's spotless as well.
Another user GAZ advised me to check a different ground connection but my garage is cramped and cold and I don't feel like it until the weather warms up.
See his advice here:
How to swap wiring harness? Difficulty? Time?
If you get to the bottom of this, please keep us informed.
Porschenut is offline
In order to be able to post messages on the Kawasaki forums, you must first register.
