Gen 4: 2011-2015 Coolant Leaking Bottom Water Pump - Page 6 - Kawasaki ZX-10R.net
 11Likes
post #51 of 55 Old 07-14-2017, 04:23 PM Thread Starter
belkins's Avatar
Originally Posted by FastAsHellZX10 View Post
when installing the new seal do I put fresh oil around it to drive it in or do I do it dry?
it has blue loctite already around the seal. you don't need to add any oil. Goes in alot easier than coming out.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #52 of 55 Old 07-15-2017, 10:29 PM
FastAsHellZX10's Avatar
Send a message via AIM to FastAsHellZX10
the manual says to drive the oil seal in with a bearing driver. those are just the flat disks right? then it says to drive the mechanical seal in with a seal driver. the illustration looks like maybe the mechanic seal driver is hollow like a socket and goes around the seal only touching the metal lip flange. am I seeing that correctly? do I drive the mechanical seal in by pressing it in by the top rubber or am i using a socket and going around it and only touching the metal lip when driving it in?
2015 30th anniversary ZX10R
Mods:Dark Tinted Windscreen, CarbonFiber TankPad, Akrapovic Full System, K&N Filter, Woolish Custom tune, 188.13 RWHP 81.46 TQ
FastAsHellZX10 is offline
post #53 of 55 Old 07-17-2017, 04:45 AM
bump
post #54 of 55 Old 07-17-2017, 02:34 PM
SkyDork's Avatar
Yes.
#WordCrimes
SkyDork is offline
post #55 of 55 Old 07-19-2017, 09:36 PM
Originally Posted by SkyDork View Post
Yes.
im not sure if I have a problem or not but I need immediate answers. when driving in the mechanical seal only hitting the outside lip im noticed little black chips stuck on the oil seal grease I added. after inspection the inside plactic of the mechanical seal started chipping even tho I never touched it.. im adding a pic, you can see that chip and there are like 3 more like it.. do I need to order another new seal and start over or is this fine? can I go ahead and install?
