Gen 4: 2011-2015 Coolant Leaking Bottom Water Pump - Page 3 - Kawasaki ZX-10R.net
 11Likes
post #21 of 55 Old 04-11-2016, 12:27 PM
SkyDork's Avatar
Originally Posted by aapulask View Post
Dumb question...
Why does oil leak out at all? Can the bike be leaned over the other way to avoid this?
Because the oil pump is behind the water pump. The same shaft is used to drive both. I suppose if you could find a way to lean the bike over the other way to do the job, oil shouldn't leak out. But then I'd be worried about some residual coolant getting into the oil. And that someone holding the bike the other way better be able to hold it for awhile. Unless you're talking about leaning it up against a wall or something.
#WordCrimes
SkyDork is offline
post #22 of 55 Old 04-11-2016, 01:05 PM
Johns04ZX10R's Avatar
The only thing I would add (too late now) is to replace the impeller shaft when you replace the seal. If the shaft is grooved or worn out of spec it will still leak with a new seal. Loose bearings will also cause them to leak.
A 1st Gen Ten will eat the hearts of grown men.
Johns04ZX10R is offline
post #23 of 55 Old 04-11-2016, 01:51 PM
GlassAnkles's Avatar
Nice work, cool puller thingy to....might have to get me one of those
GlassAnkles is offline
post #24 of 55 Old 04-11-2016, 03:19 PM Thread Starter
belkins's Avatar
Dumb question...
as skydork said the oil pump/water pump is run off the same shaft its like one unit just sealed off for each.
I don't think there would be a way to prevent it from leaking oil when you take it off besides draining the oil.. even if you drain it though it still may have a little left in there when you take it off just not as much that says SURPRISE Black Gold!! But as i said it was not very much oil that came out so it ss not really that big deal just scared the crap out of me..
I was thinking it was gonna drain all the oil out out of the bike on my garage floor... i ran to get the closest drain pan and it ended up not being much oil at all. just have a drain pan ready or some oil rags to catch the oil when ya pop it off.
belkins is offline
post #25 of 55 Old 04-11-2016, 03:21 PM Thread Starter
belkins's Avatar
yea it worked like a champ and the u bracket fit perfect on the outter edge of the pump so it did not damage anything. I looked for a slider hammer type but they only had huge ones that would not fit in the bearing to pull it out.
belkins is offline
post #26 of 55 Old 04-11-2016, 03:27 PM Thread Starter
belkins's Avatar
i did check the shafts/impeller/casing as per service manual but everything else looked good luckily. I only have 3500k miles on the bike.
belkins is offline
post #27 of 55 Old 04-12-2016, 09:42 PM
clutchcrusader's Avatar
My 2014 with 2600 miles is leaking too.Same exact thing.going to get mine warrantied though. I don't have alot of mods so why not.mine looks like like it has a oil leak too. It's leaking more fluids then a triumph.lol
clutchcrusader is offline
post #28 of 55 Old 04-13-2016, 10:15 AM Thread Starter
belkins's Avatar
crazy that these are leaking with such low miles... mine was all stock besides a slip on exhaust when it started leaking no other mods.
This is my first kawasaki.. i've only owned suzuki's before this and put tons of miles on those things without any issues besides regular maintenance. Unless kawasaki considers this to be a regular maintenance issue. I did notice the part # changed with the seal that you have to get but i could not really tell a difference between the old and new seal.
belkins is offline
post #29 of 55 Old 04-13-2016, 11:21 AM
SkyDork's Avatar
Shit happens. Some fail early, others don't. I would not say it's a common theme. I've got 12k+ miles on my gen 4 and had the water pump disassembled and reinstalled with the same parts. No leaks to mine. Sometimes you win, sometimes you don't. I don't think you'll have any more problems with it.
#WordCrimes
SkyDork is offline
post #30 of 55 Old 04-13-2016, 11:35 AM
I'm not complaining.Shit happens.gives me an excuse to go look at bikes when I drop it off.My dealers a cool place.I'm happy I seen it was leaking now.I would be bummed more if it was summer. Dealer mechanic said it's normal for them to leak a bit if the bikes been sitting for a while.Mine seems to be leaking both oil and coolant.
