Clutch cable seems tight? - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By michael4012
post #1 of 4 Old 01-20-2018, 10:04 AM Thread Starter
MichaelZxer's Avatar
Hi, the clutch cable is making the bars sort of hard to turn right. The cable seems to be tight and is rubbing the frame before it passes through the forks. (Just after the holder that also holds the throttle cables). Is this an old cable or is it adjusted wrong? The routing appears correct as per the manual. Thanks, you guys and girls rock!
MichaelZxer is offline
post #2 of 4 Old 01-20-2018, 07:05 PM Thread Starter
Anyone?
post #3 of 4 Old 01-21-2018, 12:28 AM
michael4012's Avatar
If its a gen3 then yes the cable seems to short, there was and possibly still is longer after market ones available, but to be fair although tight i don't think it should be restricting the turning. Have you looked under the side panels maybe its not routed there correctly. If you screw the lever end right in & take all the slack up on the bottom of the cable maybe you can created some slack too.
MichaelZxer likes this.
192MPH stock engined 2008
michael4012 is offline
post #4 of 4 Old 01-21-2018, 01:25 AM Thread Starter
Thanks mate, I'll take the side panel off and have a look.
