Gen 5: 2016 -> CCT Woes - Kawasaki ZX-10R.net
 3Likes
post #1 of 17 Old 08-08-2016, 10:33 AM Thread Starter
g-man's Avatar
CCT Woes
I knew it was probably coming. With 700 miles on the bike I have the dreaded CTT noise. This may also be causing the terrible Lope at idle, and backfire when decel, at the low RPMs (3-4k).
Kawasaki's $350 race kit manual unit would probably solve it, but that is a crazy price for this.
I refuse to have the dealer rip in to my bike. I can get the APE adjuster for $85, but I'm sure my warranty would be out the window with that.
I may have to just Suck-It-Up Buttercup and get the factory unit.
Any place to get it at a discount??? I will talk to my dealer, but I'm sure their hands are tied with Kawasaki unless they tear in to it.
g-man is offline
post #2 of 17 Old 08-08-2016, 11:44 AM
NixK7's Avatar
Mine does not have the CCT noise (yet) but still backfires when i close the throttle from 3-4k RPM would love to find out why
NixK7 is offline
post #3 of 17 Old 08-08-2016, 12:37 PM
renais's Avatar
Id be a bit careful about diagnosing that so early. These engines take a while to settle down and they aren't the most quiet at the best of times
chiffeee and belkins like this.
renais is online now
post #4 of 17 Old 08-08-2016, 02:23 PM Thread Starter
g-man's Avatar
I am positive the CTT is making the noise, regardless of what is causing the Lope. No idea why they would put this stock piece of crap on a performance machine.
Is anyone here using the APE adjuster? I am leaning in that direction.
g-man is offline
post #5 of 17 Old 08-08-2016, 02:25 PM
mpp12's Avatar
I hava a APE... excelent and easy to install
mpp12 is offline
post #6 of 17 Old 08-08-2016, 02:42 PM
Judge Dredd Mod
mr_honez's Avatar
I would go APE if you don't want the dealer touching yours.
BURNOUT.....
mr_honez is offline
post #7 of 17 Old 08-08-2016, 07:35 PM
The Pace
scout's Avatar
no, not the cam chain. But make sure you buy the extended as kawa will cover it between if you keep riding. Buy the extended from the AL moto site. And don't waste money on mods or race kits or whatever else the market dreams up to capture the mind. 700 miles and you believe cam chain failure. gold.
scout is offline
post #8 of 17 Old 08-11-2016, 11:33 AM
Proteus's Avatar
I can tell you from having my Gen 4 CCT fail, in addition to rattling like an old Cummins diesel at idle, it does cause a loping idle and loss of throttle response down low. Get it set right and these engines are very mechanically quiet. Somebody said the Gen 5 CCT design is different from the Gen 4 unit and can be adjusted with an allen wrench. If so, I'd do that first, Gen 4 requires removing the CCT and manually advancing it one tooth, a PITA but you shouldn't have to do it again for a very long time if ever.
Proteus is offline
post #9 of 17 Old 08-11-2016, 11:35 AM Thread Starter
g-man's Avatar
My APE CCT adjuster arrived today. Maybe I'll have time to install tonight.
g-man is offline
post #10 of 17 Old 08-11-2016, 11:36 AM
NixK7's Avatar
The Gen 5 CCT is very different than the Gen 4, if you try to adjust it the same way your gonna be in trouble.
There is a post on here somewhere all about it
Sent from my SM-G920F using Tapatalk
NixK7 is offline
