Gen 5: 2016 -> Can Someone measure the Stock length Rear brake line for me - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By 08zx10rny
post #1 of 5 Old 02-16-2018, 07:14 PM Thread Starter
Gen 5 Now!!
08zx10rny's Avatar
So i switched my Gen5 to race/track only and removed the ABS setup completely. I ordered a Non-ABS rear brake line from Spiegler and it seems excessively long. From Banjo center to Banjo center I measure about 31 1/4". Can someone measure a stock non abs rear line for me?
GEN 5!!!
08zx10rny is offline
post #2 of 5 Old 02-18-2018, 12:11 PM
My stock non-abs line is 22”. I know this because I worked with Spiegler to build a custom line. I installed Attack rearsets and everyone told me I wouldn’t need a longer brake line but it clearly wasn’t the case. I think the problem was that the Attack rearsets angled the master cylinder forward more than stock which kinked the line coming out of the master. I ended up getting a line that was a little longer and with less angle out of the master, this way I could have access to all of the adjustability of the rearsets. Now, back to Spiegler...while checking with them for the length, the guy quoted me something like 31” which I knew was way too long. He checked and thinks they went from a book of specs to putting the specs into a computer system and perhaps there were some errors. I think yours are in error. I would contact Spiegler customer support, they were really good to work with and my line turned out great. Also consider measuring for a custom line if you have aftermarket rearsets. The cost is about the same.
nwvic is offline
post #3 of 5 Old 02-18-2018, 12:15 PM Thread Starter
Gen 5 Now!!
08zx10rny's Avatar
Awesome.. appreciate the help and recommendations. I sent Spiegler a message the other day but never responded. So I guess I have to call them on Tuesday. Thanks again
GEN 5!!!
post #4 of 5 Old 02-18-2018, 02:29 PM
BAKWHEELTANGO's Avatar
Just to clarify... my bike is street/track. If I you remove the rear abs sensor - you will also lose the speed sensor. Is that correct?
BAKWHEELTANGO is offline
post #5 of 5 Old 02-18-2018, 02:52 PM Thread Starter
Gen 5 Now!!
08zx10rny's Avatar
thats not an abs sensor. Thats for traction control and speed. but it does use that informaton from that sensor while using the abs.
BAKWHEELTANGO likes this.
GEN 5!!!
